Minnesota Chapter Join Chapter, Leader: fordpower88
Cory is back in the ditch! Jan BS Thread
Old 01-03-2014, 05:48 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Originally Posted by wildstang
That's what I thought but we got around 8" of snow in temps of 0 to-6f
You just got 8"?
Sent from my HTC6500LVW using IB AutoGroup
  #47
Old 01-03-2014, 06:06 AM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
Of snow from yesterday afternoon to this morning.
  #48
Old 01-03-2014, 06:50 AM
Ford79's Avatar
Ford79
Ford79 is offline
Good morning everyone. It warmed up overnight here, -22 at 10pm and -8 at 6am.
  #49
Old 01-03-2014, 07:14 AM
Banage's Avatar
Banage
Banage is offline
-12 the 6.0 started right up. That so far is a happy new year
  #50
Old 01-03-2014, 07:52 AM
fordpower88's Avatar
fordpower88
fordpower88 is offline
Good morning, stay warm and have a fantastic snowy Friday MN.
Good morning Jim!
Originally Posted by MisterCMK
You just got 8"?
Good morning Chris! Are you jealous? You wanted 8 inches didn't you.......
Good morning Mike! Warmed up here as well. It is up to 7* above zero!
Good morning! Always nice when the truck starts up!
  #51
Old 01-03-2014, 08:13 AM
Devious Delight's Avatar
Devious Delight
Devious Delight is offline
Morning guys.
It only took me 3 days to find this thread. Lee should post sometime later today, I'd think. lol
  #52
Old 01-03-2014, 08:23 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Got the excursion running last night. Played in the new snow a little
  #53
Old 01-03-2014, 08:26 AM
MisterCMK's Avatar
MisterCMK
I bet that was a good feeling getting it running!
Now get that sled going!
  #54
Old 01-03-2014, 08:27 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
Happy Friday guys.
Congrats on the X Jim.
Got the sled back together last night with Chris' help. Thanks again Chris!
How are the new windows Troy?
  #55
Old 01-03-2014, 08:43 AM
fordpower88
Originally Posted by Devious Delight
Morning guys.
Good morning Dustin! Yeah the new thread is pretty tricky to find up there at the top of the thread list!
Congrats Jim!
Originally Posted by DieselCamper01
Happy Friday guys.
Good morning Jay! New windows are good! They have a couple left that they were waiting for a nicer day to put in which happens to be today so they should all be in by the end of the day. They have all the siding off and the house wrapped so the new siding will be up next along with the new doors.
  #56
Old 01-03-2014, 09:01 AM
DieselCamper01
Sounds good Troy.
  #57
Old 01-03-2014, 09:26 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
It was a great feeling. Until I drove it the first time. The power steering pump was whining bad, intermittent power steering and brakes, and when putting it in reverse, it would hesitate then bog engine down and sometimes stall it. Fortunately just had to get the air out of the pump and top it off and add almost a gallon of trans fluid and seemed to fix that problem. So now it is a good feeling. Didn't think I had lost that much fluid and when I first checked it seemed to register on the stick. I do a slight exhaust leak at the exhaust manifold/up pipe connection on driver side. I think that is fairly easy fix, I didn't tighten up the bolt on each side evenly so it cocked it off to one side more than the other. The up pipes are the dorman bellowed ones. Also have a Riff Raff FRX regulated fuel return to put on that I forgot about.
hopefully start getting the sleds ready this weekend
  #58
Old 01-03-2014, 10:48 AM
msmenne17's Avatar
msmenne17
msmenne17 is offline
Good morning everyone. It's a balmy 11* here. Hopefully, it's warm enough I can work on my snowblower again. I was able to use it last week to blow the driveway, but it wasn't running right, so I'm going to pull the carb apart again and clean it really good.
Anyone boiled a carb in water and vinegar? I saw someone post that they boil them for 45 minutes in a water/vinegar solution, clean em out, then boil them in water for 45 minutes again and spray out with carb cleaner and reassemble.
  #59
Old 01-03-2014, 11:05 AM
DieselCamper01
Seems like way too much work Michael. Take it apart as much as possible and sparay every opening you can with carb cleaner. Done.
  #60
Old 01-03-2014, 11:10 AM
Devious Delight
Quick Reply: Cory is back in the ditch! Jan BS Thread
