Yes to fuel and it had oil in it. Don't forget she was only seeing 54.8 psi while cranking on the hpo. Ebp with key on engine off was 14.8 iirc. This isn't my first rodeo but I know a few of you guys drive 6.0s and its no big deal since its not mine and is at the dealership. I just wanted to make sure I covered my above basics. A 6.0 is new to me as most of my knowledge is 7.3 but since the 6.0 and 7.3 are so closely related I figured I'd be close. I'm wondering if it's a low pressure oil problem
I've not read anything on the lpop having an issue unless there is something major wrong in the engine, bearing failure, metal shavings messing it up. The check valve on the housing is another story, it can fail causing low oil pressure.
In the 7.3 world it's not exactly a common thing for a low pressure pump to go out but when it does it kills oil to the hpop, obviously. Well see what the verdict is when it's out it the shop
That's because the 7.3 world is cool (although I am not). And our trucks appreciate in value in factors that are unfathomable by most mathematicians, and we drink beer to the point of making stuff up....
Other than the degas bottle, which means head studs are in my future... hell I'm building a barn and installing a hoist just so I can remove the cab and work on it... yeah it's been hell, but worth it, because I really like the sun roof.
Only seeing 54psi is quite low and is indicative of a rather large leak in the HPO system. I've been there a few times and feel your pain. What year truck?
