IMPORTANT Michigan BS - Required Reading!
#6349
Jimmy's on a roll today.......
It would seem much more productive to just replace with another Y pipe. That is definitely a place I wouldn't want to have to get to multiple times.
#6351
I may have to add the Sinister Y pipe to my list of wants for the truck, I see they even have a nice set of exhaust manifolds available as an upgrade to the factory ones.
#6352
HAHA, yeah, I guess having your truck in proper working condition makes you in a good mood.
I got tired of going in there after the second time. First time, fine...second time 6 months later, OK, this sucks and I need a more permanent repair.
The original pipe lasted 215K miles and started with a very small leak, so I bought a new OEM pipe and had it installed when the studs were done. Less than six months later, the flex blew out on the new pipe and squealed at idle. I started looking for options after I re-installed the original pipe, I was not going to buy another OEM pipe.
#6355
yep. it is. But pricy too. $522 for the manifolds, $499 for the Y, then gaskets bolts and seals. Also while the turbo is off it would be a good time to clean up and do any maintenance needed on that, then there is the oil pipe to the turbo, that may as well get done too.
#6358
i will be home with the kids from 6:30-8:30'ish. so if you want to stop by the house, anytime, otherwise Railtown would have to be post-8:30.
