IMPORTANT Michigan BS - Required Reading!
#5641
everyone have a good weekend? i figured out at least part of my vacuum issue on the truck this weekend. pulled the vacuum reservoir box out from behind the battery and it was all busted up.
new one will be here tomorrow, but in the mean time i tried to glue it back together in hopes of improving my symptoms (grinding IWE's under load, rough idle, hesitation when taking off moderately, occasional stumble when starting), but no change. still have hope new one will clean all that up, but if not i'm going to need to find a vacuum/pressure tester and dig deeper.
#5642
Hope it will work out for you Brandon.
Hard to believe it's Monday already. This weekend is going to be interesting, I'm going to help my buddy on his show truck. Which by coincidence is supposed to be at Autorama in Detroit when we meet up there on March 7
#5643
I think I'm the only guy here with a DEF equipped truck, but just in case any of you buy one, Mercedes now has protective covers for use when servicing your DEF system.
#5647
When I moved the Tiki Bar to Silver Lake, I just had to get a $10 permit, red flags, and an over size load banner. They recorded the dates and times of travel. Gave me a piece of paper for the cop if I were to get pulled over. Because I had the permit, it was not necessary to speak to an officer of the law. I am pretty sure if I hadn't spent the $10 I would have!
The bridge brings up another good point. The cost is per axle. Might be quite the shock to cross. $10 for a normal van if it's commercial.
#5648
The permit will be a must for me. I'm not that concerned about the commercial cost, that would only come into play if I was hauling for hire. Being a private owner, it should be a non issue.
Thanks for the heads up though Torr.
#5650
I seen a 5th wheel flat bed trailer yesterday for sale near me. Didn't see how long it was or a price, but I'm betting not as cheap as a motor home frame.
What kind of show truck does your friend have Rich? I'd sure like to get my bronco done as a show truck, but one can only dream for now.
Also how much would you guys pay for a NEW tailgate? Because JBG is advertising $950 for my 97', but it doesn't have any description. Pickup Tailgate 1992-97-Broncograveyard.com
#5651
