IMPORTANT Michigan BS - Required Reading!
#3256
Lets do it right if were gonna do it..... I need TWO 55 gallon drums, 4 old tires, charcoal fluid, a roman candle half of Mikes beer supply and at least two other drunk buddies to record what's about to happen. I say two buddies because theres a chance one may not make it through this
#3258
tried hard to win a Weber grill on repocast last night, no dice.. couldn't bring myself to pay that much for a used grill. bummer.
#3260
Another friend of mine is in a local band, they are a bit better. Ivan is the one with the black Les Paul smoking the cig.
https://www.youtube.com/watch?v=EVytIMkabr0#t=11
#3263
much better for a GTG.....
I still think we need to set em up outside. would be deaf if we really wanted to make a working GTG out of it.
speaking of that I still have front wheel bearings to do.
#3269
Throwing code P2285 ICP Sensor Circuit Low, only seems to through it after truck has been sitting in the sun. when I hook the truck up to AE and check the sensor vs the desired ICP and it is almost right on the voltage curve looks good as well and matches the conversion table for the sensor. If I clear the code it is good again until the truck sits in the sun. Also tried several start ups and jiggling the pigtail between start ups to see if it was shorting out and couldn't duplicate. Truck seemed to surge a bit yesterday when code was thrown at lunch but smoothed out.
#3270
Try unplugging the sensor, it will send it into default. That can help you at least rule out something goofy with that even though that doesn't sound like the problem.
It sitting in the sun shouldn't matter one bit for anything.
