2008 Explorer - RSC Issue - Ford Truck Enthusiasts Forums
Old 12-31-2013, 07:35 PM
LashLaRue LashLaRue is offline
LashLaRue is starting off with a positive reputation.
I'm currently having an issue with our 2008 Explorer, 4.0L, 4x4 RSC. The RSC light will come on, and there is a dinging sound. This has happened in the past, usually in town, slower speeds, etc. I had it checked out, but no codes were being thrown. The brakes (rotors & pads) are fairly new and in good working order.
Well, tonight it happened at ~70mph. It felt like each brake was individually depressing, even though the brake pedal had not been touched. I assume it's a sensor but plan to get it into the detailer on Thursday.
Thanks for your help.
Old 01-01-2014, 03:33 PM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
You mentioned that previously it gave an indication but no codes were being thrown. Were you using a professional scan tool to check for codes or the typical consumer grade that you can buy or borrow from the local parts store? The consumer grade tools typically cannot access ABS or traction control codes.
It sounds like you probably have a wheel speed sensor or tone ring issue. A professional scan tool should help diagnose which sensor is reporting an issue and make pretty quick work of getting the issue resolved.
-Rod
2008 Exp EL, RSC light (car w/ squiggly lines) on. 98explorerltd 2007 - 2014 Expedition & Navigator 0 07-12-2016 12:11 PM
08 Ford Explorer ABS-Roll Stability-PCM HTMEEE Explorer, Sport Trac, Mountaineer & Aviator 1 05-08-2016 10:50 PM
ABS RSC Warning Light Power Stroke 7107 Explorer, Sport Trac, Mountaineer & Aviator 6 01-04-2015 05:54 PM
explore sam88 Explorer, Sport Trac, Mountaineer & Aviator 1 05-21-2014 08:01 AM
RSC squiggle vehicle icon on message center random scholzee 2007 - 2014 Expedition & Navigator 1 02-18-2012 10:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
