heater question - Ford Truck Enthusiasts Forums
heater question
Old 12-31-2013, 03:48 PM
lilrobo's Avatar
lilrobo lilrobo is offline
lilrobo is starting off with a positive reputation.
heater question
i have ask before and i know ford put a lot different heaters in there trucks , but i am looking for the adapter that the hose fits onto i haver 1 but i need another you see it here does anyone have any ideas,, i have talked to mid fifty's and another parts shop
Old 12-31-2013, 07:07 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Send a PM to firstrider. I think he's our resident heater expert.
http://www.ford-trucks.com/forums/12...and-parts.html
Old 12-31-2013, 07:49 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
what about an exhaust adapter? Easy enough to get one to fit over the heater outlet and reduce down to a size the hose will fit over.
Old 01-04-2014, 02:24 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
The way the heater has the "locks" or "tabs" on it tells me that the hose slips over the heater ports, no adapters. Mid fifty does have plastic ones to go from 2 1/2 to 2" because '56 is different then '53-'55.
1948-79 Ford F-100 Air Hose Adapter, 2 To 2 1/2
Old 01-04-2014, 06:20 AM
lilrobo's Avatar
the size on heater box is 3 inch,, i got a adapt made ,, now i need to find out the hose is run ,, the glove box seems to be in the way , on pass side ,, i been tiring to find a pic
thanks
Old 01-06-2014, 10:10 AM
lilrobo's Avatar
I got a adapter made from a muffler shop , now i need to run the hose, does anyone have a pic showing how it is run? the glove box seems to be in the way, , maybe it goes way around it?
Old 01-06-2014, 11:30 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
There were many different kinds, brands and designs of heaters installed in these old trucks and they were not always installed by dealers.
Here is the best shot I can get of the Ford heater in my '56. The defroster ducts for driver and passenger side both run from a manifold off the heater. The passenger side runs up behind the glove box. Probably have to pull the glove box to position the hose onto the defroster deflector.
Sorry for the not so good pictures. HTH
Old 01-06-2014, 03:21 PM
lilrobo's Avatar
Thanks for the pics, , but it looks very different than my 53, once it warms up a little i will see if i can take out the glove box and try it that way
Thanks again
Old 01-06-2014, 07:43 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
After further review I noticed that the hose slips inside the defrost duct . Not OEM .The hose should slip over the defrost duct . I think some one fabbed a home made locking device . Measure the size of the defrost ducts, get some defrost tubing that will slip over them & do it right .That is what the little triangular tabs are for on the defrost ducts to hold the defrost hose / tubing on ..
Old 01-06-2014, 09:13 PM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
Can you this be used as a reducer?
Canplas 103024RTL ABS Coupling Fitting, 2" x 3"
Old 01-06-2014, 10:08 PM
lilrobo's Avatar
i got the adapter done , i just need to route the hose behind the glove box
thanks
1953-54 seat cover for sale lilrobo Ford Truck Parts for Sale 0 12-13-2013 04:35 PM
its begun lilrobo 1948 - 1956 F1, F100 & Larger F-Series Trucks 67 10-29-2013 05:41 PM
new new seat covers lilrobo 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 10-19-2013 05:43 AM
new interior lilrobo 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 10-08-2013 07:42 PM
walnut bed pics lilrobo 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-12-2013 08:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
