Interior door trim clips / fasteners? - Ford Truck Enthusiasts Forums
Old 12-31-2013, 02:43 PM
bb65f1004x4 bb65f1004x4 is offline
bb65f1004x4 is starting off with a positive reputation.
Where can I find these little #$!@*&...? I looked thoroughly where I would normally get parts. I never see 61-66s at the junkyard and anything on ebay has the trim for sale too. I only need $0.15 worth of bent steel. Where can I find them? Otherwise creativity will be necessary.
Old 12-31-2013, 02:54 PM
TA455HO's Avatar
TA455HO TA455HO is online now
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
carolinaclassics.com has them, $1.60 each. Listed in their catalog on page 62, their part number: 378586
I assume that is what you are talking about. Not cheap but there are not a lot of other options if used isn't available. See if this link works.
http://www.carolina-classics.com/Det...181&category=0
Old 12-31-2013, 04:38 PM
napass2004 napass2004 is offline
napass2004 is starting off with a positive reputation.
They also have a reproduction clip a little cheaper at Carolina classics part number 13173
Old 12-31-2013, 07:02 PM
TA455HO's Avatar
Old 01-02-2014, 12:00 AM
I can't say thanks enough!!! I see you commented on my other post. I will definitely be shelling out the cash for those.
Rear window WIDE metal trim four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-13-2015 06:00 PM
Narrow molding trim? 1978 f250 custom Louislindsey72 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-16-2015 03:47 PM
66 F100 Dash Trim rwrogers 1961 - 1966 F-100 & Larger F-Series Trucks 10 11-23-2014 11:10 PM
Fast and Loud Tony65 1967 - 1972 F-100 & Larger F-Series Trucks 21 11-16-2013 12:28 AM
Seat trim removal ccecilm2 Explorer, Sport Trac, Mountaineer & Aviator 3 09-30-2007 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
