Load Testing Alternator On Vehicle - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 12-31-2013, 01:48 PM
makuloco2000 makuloco2000 is offline
makuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to all
I made a brief video on the procedure I have used for many years here at the dealer that has not failed me yet in identifying a weak but functioning alternator causing many headaches like no starts after changing the battery and only checking the voltage output of the Alt. I hope this helps as there really isn't a need to take the alt off to get it tested. No fancy tools required.
Old 12-31-2013, 02:22 PM
TheyCallMeBT TheyCallMeBT is offline
TheyCallMeBT is starting off with a positive reputation.
I could have used this about a year ago with my F-150. The alternator registered at the auto parts store as functioning using their diagnostic equipment, but it was indeed the problem. Thanks for sharing!
Old 01-03-2014, 09:07 PM
Nice just goes to show taking it off the be load tested isnt always the solution.
Old 01-07-2014, 02:43 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
The auto parts 'dummy' equipment is mediocre at best. I went their last week to test my battery. Tested OK, as did my alternator and starter. Ran the test again, car wouldn't start, only click. Test still showed all three ok. Turned out starter was bad even though it showed up as good.
Blower Motor Only Works On High makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 2 06-15-2014 04:40 PM
Another aftermarket thread run6.0run 6.0L Power Stroke Diesel 37 02-25-2014 03:16 AM
4.6L & 5.4L Engines Alternator Replacement makuloco2000 2004 - 2008 F150 0 02-20-2014 12:24 PM
4.6L Power Steering Type Whine Noise makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 1 02-04-2014 10:39 AM
alternator testing RobertJohn 1999 - 2003 7.3L Power Stroke Diesel 2 01-20-2014 07:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
