Planning F1 or F100 ( 50`s) overhaul - Ford Truck Enthusiasts Forums
Old 12-31-2013, 10:40 AM
MBfreak MBfreak is offline
MBfreak is starting off with a positive reputation.
Ford pu noob here. I am presently hoping to get hold of a 55 F100 or a 50 F1. These kind of vehicles are not common in Sweden.
While chasing I also try to plan the restoration work. I will definitely make a full frame off job. I believe that once the frame has all bolted parts removed it can be lifted and moved by two persons.
Is this correct and what is the approx mass of a F1 or F100 frame when all bolted parts have been removed?
Best regards
Ola
Old 12-31-2013, 10:58 AM
tip49's Avatar
tip49 tip49 is offline
tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.
Welcome to the Forum
Ola;
A cab can be lifted by one person, from the frame if you have a rolling jig built that is at the same elevation as the frame; but three to four people would be ideal. I don't know the weight (mass) of the frame itself but two people would be able to lift it, if it was stripped down. Welcome to the site!
Tom
Old 12-31-2013, 01:41 PM
pholmes350's Avatar
pholmes350 pholmes350 is offline
pholmes350 is starting off with a positive reputation.
I am doing a frame off on a 53 F100 and could move the frame some by myself. I would guess about 400lb (180kg). Two people can move it but 3 or 4 would be best as Tom suggests.
Valkomna!
Old 12-31-2013, 02:22 PM
Frame weights
Hi and thanks for the replies.
I wil plan to have a couple of strong friends to help me. The frame will be caried on to my back porch ( 7x10 m with a concrete floor) thru the garage, once it has been initially sandblasted and painted with some light rust protection.
After it has been straightened, adjusted, welded and whatever it will go back to the paintshop for final blasting and powdercoating.
However, this is a bit of daydreaming, have given offers on a F1 and a F100 and hope to get the F100 which is in very restoreable and unmodified condition.
Best regards
Ola
OT. Do you live in Scandinavia? jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 05-17-2015 02:43 AM
Hello from Sweden MagnusB New Member Introductions 8 12-26-2014 06:03 AM
OIL winter F150 2006 SwedMartin Oil & Lubrication 2 08-19-2014 10:51 AM
Questions about driveshafts :) ex3em 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-11-2014 11:19 PM
Ford noob from Sweden intro to plans MBfreak 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-29-2013 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
