Rim offset - Ford Truck Enthusiasts Forums
Rim offset
Old 12-31-2013, 08:17 AM
oscajo oscajo is offline
oscajo is starting off with a positive reputation.
Rim offset
What offset rim works the best on a 52 F1 with stock front axle to fill wheel wells and look great?
Thanks,
Oscar
Old 12-31-2013, 01:28 PM
Rich56's Avatar
Rich56 Rich56 is offline
Rich56 is gaining momentum as a positive member of FTE.Rich56 is gaining momentum as a positive member of FTE.
Might be easier to just measure the clearances yourself and figure the backspace that would work best, all sizes of rims out there plus each rim size can take different sized tires, section width and heights come into effect now.
Lots of good charts to help in picking sizes, google around.
Just did my whole truck, but not your set-up.
Old 12-31-2013, 01:56 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I am running a stock type 15" wheel reversed about an inch with 205/75-15 tires. Truck is also lowered a couple inches.....
Old 12-31-2013, 02:06 PM
wallster's Avatar
wallster wallster is offline
wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.
Here's a great tutorial on how to measure for your new wheels (ie. backspacing, offset, diameter, and width).
Wally
ps. Here's a good reference for tire measurements based on sizes. http://www.tirerack.com/tires/tirete...e.jsp?techid=7
Rim offset book vs actual ThoobHertz 2009 - 2014 F150 2 06-19-2016 10:32 AM
2015 rims neg. offset AURIE 1999 to 2016 Super Duty 1 06-29-2015 11:40 AM
Offset rims for 1992 ford f150 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 1 10-07-2011 03:22 AM
Rim offset lakewood 1999 to 2016 Super Duty 12 08-30-2011 07:34 PM
backspacing/ offset of stock rims? cowboyup1988 1999 to 2016 Super Duty 15 03-05-2010 08:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
