Help with identifying rear end - Ford Truck Enthusiasts Forums
Old 12-31-2013, 12:22 AM
Bluey Zedoff's Avatar
Bluey Zedoff Bluey Zedoff is offline
Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.
Guys. First of all Happy New Year to everyone
Hope 2014 brings you lots of big fat fendered surprises!
Not sure whether I am being paranoid or not, but can someone verify that my rear end is more or less the rear end that the good Lord (Ford motor co) decided should go under the truck?
I have a feeling it aint original.
I have just taken out of pair of old shock absorbers from the rear end. Brackets have been welded to the axle. See the brackets lower left and right. The shocks are mounted to a bracket directly above them.
Now. On the top of the diff, there are two mounting holes. For what, I know not. Can someone advise? Should there be shock absorbers there at all?
Should I stop drinking right now and sober up?
Am I going mad?
I know I should buy a manual, but there's not much left on this old girl that is original...
Old 12-31-2013, 12:29 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I'd say it looks like a Pontiac 10 bolt rear. Possible from a Lemans, Tempest, GTO.
Old 12-31-2013, 12:37 AM
Hi Wayne. Looks like you are on the money there, mate. It didn't look like anything Ford put out, but I wasn't sure. So it may be a ten bolt rear...
Hmmm.
Old 12-31-2013, 06:32 PM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
38Chevy454 is starting off with a positive reputation.
It's a GM 10-bolt. Somewhere on the web there is an ID chart, those small square corners at the bottom approx 5:00 and 7:00 position are specific to that version.
Since you have the triangulated four link bar mounts, it is most likely out of an A-body (Chevelle, Lemans, Cutlass, etc).
Bilstein Shocks Installation on my F-250 Adirondacker 1999 - 2003 7.3L Power Stroke Diesel 80 04-04-2015 07:37 AM
Pulling to the right - oooops parkland 1999 to 2016 Super Duty 9 11-03-2014 07:40 PM
MII Front end coil spring question Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 02-25-2014 03:05 PM
custom rear shocks brackets 400inatruck 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-24-2012 10:31 PM
1973 F100 Shock Absorber Dimmick24 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-29-2012 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
