Y block question - Ford Truck Enthusiasts Forums
Y block question
Old 12-30-2013, 11:55 PM
BAMA_FAN's Avatar
BAMA_FAN BAMA_FAN is offline
BAMA_FAN is starting off with a positive reputation.
Y block question
I have a 54f100 with the y block ,and I want to put the igniter point replacement in the distributor, but I can't see the distributor number. All I can see is ford engraved on the side any suggestions on what kit or number to use?
Old 12-31-2013, 10:58 AM
greenmachine55's Avatar
greenmachine55 greenmachine55 is offline
greenmachine55 is starting off with a positive reputation.
Pertronix 1282 I used on my 1954 Y block engine. I have not had any problems and starts every time!
Old 01-01-2014, 12:26 PM
TxF100's Avatar
TxF100 TxF100 is offline
TxF100 is gaining momentum as a positive member of FTE.
Be sure that you do not have a replacement distributor. The replacement ones could be the 57 up style which use a different part number.
Old 01-01-2014, 12:35 PM
TxF100's Avatar
The 1957 and newer distributor has a vacuum advance as well as a mechanical centrifugal advance located under the breaker plate.* Special weights dampened with small coil springs advance the breaker plate when required by increases in engine r.p.m
312 Y block distributor points question 51FordTN 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 03-18-2015 06:53 PM
Swapping Distributors? Ratty Truck Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 08-11-2014 09:01 AM
390 distributor ? jlb51 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 01-22-2014 10:14 PM
Distributors that fit Y block 292 3414 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-28-2010 09:28 AM
Y block distributor 569104 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 01-19-2010 11:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
