"firestone" heater for my 51 F1? - Ford Truck Enthusiasts Forums
Old 12-30-2013, 11:29 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
I just bought this heater off ebay, I think it is a firestone brand from what I have seen in one post? Were these factory or dealer installed? The heater core outlets and mounting bolts line up perfectly wtih my firewall so I would guess this what my truck had. I cant afford an A/C unit right now but have to have at least a heater and defogger so I got this one to use. Look correct?
Old 12-31-2013, 12:03 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
It's a dealer install. If the truck didn't get the Magic Air heater, then something like this heater was used.
Old 12-31-2013, 09:30 AM
drptop70ss's Avatar
No magic air in this one, the side plate in the firewall is still there from the factory. This was a 5 star cab too, I would of figured it would get a heater.
Old 12-31-2013, 09:56 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Back when, heaters were installed by whomever needed a heater, not necessarily the dealer. Lots of aftermarket brands. Since your truck appears modified, the heater being correct should not be an issue. A working heater in your area would be a requirement.
As late as the 1960s, heaters were optional. I know of a 1960 Chevy Impala, top of the line, that had no heater.
Old 12-31-2013, 10:33 AM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I have a BFG heater that is pretty neat looking.I also have firestone and BFG radios I have found.I grab that stuff when I can, all mine seem to be 6v.If I can find them I will take a picture.
1951 Ford F1 resurrection, jag IFS LT1, EFI, T56, etc drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 425 01-17-2017 10:09 PM
Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc.. drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 420 11-09-2016 10:41 PM
F1 latch repairs, fix the sag and make them work! drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 11-05-2015 09:43 PM
LED replacement bulb info, dont bother with them drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-19-2015 06:40 PM
rear cab to frame measurement needed drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2014 11:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
