Is it classic is it worth it
Old 12-30-2013, 09:04 PM
simsdan's Avatar
simsdan
simsdan is offline
I am looking at 1969 Ford F100. Is this a classic? It has a solid body some rust but not thrashed. Frame good has 360 v8. Is that the original motor. It needs wheel cylinders put on (already) bought needs some carburetor work one seal leaks. I can get it for $750 cash. Would it be worth it?
I just like to fix it up and drive truck shows
Old 12-30-2013, 09:16 PM
lineman113's Avatar
lineman113
lineman113 is offline
That is pretty cheap. You need to take a close look at the cab mounts to see if they are rusted out. Also check the floor pans. If not and the other rust is not that bad I would say it is a good deal. You can keep these trucks going for a long time, but you should expect to run into some challenges while working on it. Lost of parts have been together a long time and will not want to come apart. You can use the vin number to find out what size engine it had in it when new. A 360 was used in many of these trucks.
Old 12-30-2013, 09:41 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Is it a classic? To some yes, to some no.
Those that say no are merely lemmings who think it's just an old truck that is as aerodynamic as an aircraft carrier, wastes gasoline, is loud and noisy, has no air bags or anti-lock brakes, is environmentally irresponsible with no cats or oxygen sensor, rides like a bucking bronco, and whose bench seat feels like an upholstered park bench.
Ahhhh the good ol' days....
Old 12-31-2013, 08:08 AM
derbydad276's Avatar
derbydad276
derbydad276 is offline
no you wont like it ...
tell me where its at and Ill pick it up and save you the time
Old 12-31-2013, 08:24 AM
19fifty4's Avatar
19fifty4
19fifty4 is offline
Go for it.
Old 12-31-2013, 09:37 AM
Gembone's Avatar
Gembone
Gembone is offline
Hard to say without pics, although sounds like it's more truck than most people can get for that price.
Do a thorough check of it and if you like it, buy it.
Old 12-31-2013, 12:11 PM
carchub's Avatar
carchub
carchub is offline
I say if it runs, goes, and stops, $750 is a helluva deal. I bought my '72 for around the same price, if you pull through with this one then you've got me beat in bargaining!!
Old 12-31-2013, 01:02 PM
flyboy2610's Avatar
flyboy2610
flyboy2610 is offline
From your description, $750 sounds like a good deal!
Do it, man!
Old 12-31-2013, 01:04 PM
Aesop's Avatar
Aesop
Aesop is offline
Maybe
I don't think it is a classic. there were about 4 million 67-72 ford trucks built. However, I think it is the best looking body style ever produced. They are easy to work on, parts are plentiful, and the mods are endless. 2wd body parts are direct bolt on. The frame and drive train are worth $500-$750 if the frame is not tweaked or rusted out. Your cab most likely needs floorboards, look under the carpet where the kick panels and floorboard meet. Cobbled wiring is always an issue but easily fixed. The bottom of the doors are prone to rust out and the window seals are probably trashed. Look at the interior of the bed all the way forward. The bed floors rust out due to poor drainage.
Sounds like a good deal unless it has been used as a stump jumper.
tk1251k
20
05-09-2017 08:37 PM
bra$$monkey
12-11-2013 05:16 PM
iversun
31
12-30-2012 02:36 PM
norvillebob
10-04-2006 06:30 PM
dquack
13
05-08-2006 09:26 PM
Quick Reply: Is it classic is it worth it
