Searching For Parts
Searching For Parts
Gentleman I am in need of a set of rear lower shock mounts . Our truck does not appear to have had any installed from the factory . It's a Mercury version of the F3 . The mounts I have seen are built into the spring U bolt clamps. Does anyone have a spare set available for sale .
parts
The rear shock mounts are different between F1 and F2/3 trucks. The F1 are smaller than F2/F3 and will not work on thicker rear axle of the F2/F3.
I parted out two 52 F3s recently and both had the rear shock mounts, uppers and lowers. The first set went to aussiecowboy for his F3 and I'm saving the other set to hopefully use in my 51 when I install the 9" rear.
With so many F2/3s popping up recently, and most being modified, I'm sure that you'll find a set.
Roger <> Roger
Sorry couldn't resist!
I have a 9" rear end laying in the garage waiting to go under the F-1 and a pair of those 3" mounts here somewhere? There may have been a second pair but will have to dig around a bit to see. people have started to call me a packrat lately so I guess I better start selling something
I'll see if I can scare up an extra set of those brackets.
49willard
10-10-2005 08:27 PM
Dan_the_Ford_Man
04-17-2002 05:32 AM
