Wondering if I may need to do an axle swap?
I do think that Sterlings (10.25" or 10.5") are considered stronger than a Dana 60 though.
no powerstroke has ever come factory with a D44. You are looking to make you regular D44 to a HD44. I forget if the spindles are the same as the standard 44 but at worst you looking at taking everything from the knuckle out. It would probably be just as cost effective to just swap the axle. The 14 bolt and the E350 axle will be the old standard 8 lug pattern. I'll take a 14 bolt any day over a sterling 10.5 any day of the week. Bigger gear set, 3rd pinion bearing, easy to set up, and cheap.
NW 150
12-31-2013 09:37 PM
archer_ski
10-16-2013 07:20 AM
1979fordf150rebel
01-25-2012 11:03 AM
