My dually conversion, with some porn.. - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 01-14-2014, 06:01 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Quote:
Originally Posted by stainlessstroker95 View Post
Thats gonna be one heck of a towing rig this summer Darin. Hope it all turns out the way you want it. At least till next winter haha.
LOL! Good one Gabe! You never know!
Thanks Glenn, that is what I'm gonna do.
  #122
Old 01-14-2014, 07:22 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by 427 fordman View Post
No, I bought them from someone on here and they weren't with them. There isn't anything special about them, is there? I had a 9/16 bolt with a shoulder/thick washer on it that fit well, so was going to look for 16 like it. Was thinking I'd loctite them in and be good.
Glenn, I think I got what you are saying. I'm gonna tackle this before I do any more work on the box in case I need to shim it to make the body lines line up.
I will have to look at my space sets of hubs. IIRC they have a splined shoulder kinda like the SRW single hub
  #123
Old 01-14-2014, 06:25 PM
Thanks Brad. I'm going to town thursday and I was going to get some then. There is a small "v" cut in the rotors for the studs to go in originally, but there is a more solid hole under that (if you know what I mean). About half of the rotor hole has the v in it, the other half is just a hole. I was thinking a guy would be ok with a fairly normal bolt means that the v is only half way through the hole.
  #124
Old 01-18-2014, 04:59 PM
I worked on the body bushings today. Man, that sucked. I ended up cutting them all apart, only way they were coming apart.
I have a question. I put new poly mounts in, but don't have a complete solid bushing inside like the stock rubbers. The way I cut them is pushed up from the nut on the bottom with a jack and socket, then cut them in half above the frame mount. Except for the drivers side rear. That was terrible. It is by the fuel tank, so I moved the box back and cut the living crap out of that one to get it out. So I have most of the sleeve in the rest, but not all in there. I don't have anything mounted permanently yet, its just sitting on the new bushings. Is it necessary to have that complete metal sleeve inside the poly bushing? I can't see it being necessary, but thought I'd ask. I used the upper washer with the sleeve on it till where I cut it.
The only real bad one was the passengers side rear one. It raised up about 3/4 of an inch. The body line was way off on the box, but now is just about right.
  #125
Old 01-18-2014, 06:30 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
The old chain and jake didn't work?
  #126
Old 01-19-2014, 05:14 AM
Quote:
Nope. I started with the drivers side rear which was beside the fuel tank so it wouldn't have worked without moving the tank, and that wasn't going to happen. After fighting with that and getting nowhere for a while, I did the other rear one. I tried the chain and all I got done was lift the truck off the floor.
I then said pi$$ on it and cut them off..
  #127
Old 01-19-2014, 05:24 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Those body mounts can be a huge PIA sometimes. I've had to cut them out before too.
  #128
Old 01-19-2014, 05:29 AM
Did you worry about the metal sleeve when you put the new ones in Bill? I just don't see it being necessary with the poly, maybe it is? Like I said, I used most of it with the top washer, but it got cut and using new bolts.
  #129
Old 01-19-2014, 05:35 AM
ReBilld's Avatar
I've never installed poly body mounts before, but I think you would be ok without it. It is actually a two piece deal, one slides inside the other, I guess so the rubber mounts can give a little.
  #130
Old 01-19-2014, 05:38 AM
Good point. Originally they were made like that. Over time just seized into one. I think they will be ok too, I'm running with it.
Thanks bud.
  #131
Old 01-19-2014, 08:47 AM
I don't know how far you actually lifted the truck but I lifted mine until the wheels also came off the ground on the side I was working on. Pretty amazing how tight a flared two piece sleeve can hold together that strong. The directions say to grind that flare off when putting them back together so what was the point of the flare in the first place?
  #132
Old 01-19-2014, 10:10 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
So theres a metal piece on top and on bottom with the threaded part the bolt attaches from the top in the bottom?
The chain or puller is pulling the lower part out of the upper? Im trying too wrap my head around this....if i ever get my bushings in...my buddy is killing me on these things..
  #133
Old 01-19-2014, 10:29 AM
The metal piece on top has a sleeve like pipe that meets one from the bottom and they squeeze together and a flare keeps them together. The bottom has the threads and the bolt goes in from the top. The bottom piece is a big flat like washer with a 'pipe' attached to it with threads. You remove the bolt from the top, then thread it into the bottom thru chain links, if you do this method of removal. The chain is looped under the floor jack so when you jack up on the frame it pulls on the bottom piece. The two flared pieces that meet in the middle from the top and bottom and fit together really tight. I could not believe how much I had to jack up the pickup before they let loose. It was like a gun going off, LOL As far as the rear fuel tank, loosen the strap in the front and remove the one in the rear to swing it out of the way a little. I used a racket strap to hold it up and out of the way. The fuel tank connections on top do not have to be unhooked.
  #134
Old 01-19-2014, 11:25 AM
Glenn, I lifted the truck way off the ground and let it sit there. I sprayed PB in there, beat on it, etc., and had no luck. Finally said screw it and cut them all out. Didn't even try it on the middle ones. Front bolts broke loosening them. I didn't want to mess with the fuel tank strap, so I slid my box back (not mounted yet) and got at it from the top. I was able to pry the thick rubber part up and cut underneath it.
  #135
Old 01-19-2014, 11:41 AM
Wow, my tires were starting to come off the ground but not all the way off.
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 10:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 10:01 AM
1939 Ford truck information 31hillard 1947 and Older Ford Trucks 23 09-14-2014 11:02 PM
Finally started my York Air today 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 39 12-15-2013 12:08 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 04:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
