My dually conversion, with some porn.. - Page 7 - Ford Truck Enthusiasts Forums
  #91
Old 01-06-2014, 04:13 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I don't drive it empty hardly at all. It's not bad, but you know they are there! Normal roads are just fine empty, its just the real rough ones that'll get your attention. With the trailer on, its excellent.
If I drove it empty much I would have put smaller springs and air bags on. This way was much cheaper for me, and works well for what I need.
Brad, they are 10 plus the overload. They are brand new takeoffs from a '12 F550.
  #92
Old 01-08-2014, 02:58 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is online now
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
That looks awesome Darin! You are doing a excellent job!
  #93
Old 01-08-2014, 03:06 PM
Thanks Phil! Got my tires, fuel hoses, and a couple little things today, so I should have everything to finish it.
  #94
Old 01-08-2014, 03:34 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
Are u going to do any rust provention on the frame? Looking good and I think that thing got more spring them my f450.
  #95
Old 01-08-2014, 04:09 PM
Thanks Doug, I'm not going to do any now. I'd like to, but I don't have time. Too much other stuff on my plate, I just need to get it together and out of the shop for now. The frame is rust free now, besides maybe a little surface rust in a couple places, doesn't look so good in the picture, I was on a lot of wet gravel roads before I pulled the box. I hardly drive it in the winter, and if I do, I avoid the salted roads if possible.
  #96
Old 01-08-2014, 09:45 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
What the fuel hoses for Darin?
  #97
Old 01-08-2014, 09:51 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Man that 5" pipe looks good! You're making some good progress buddy! You don't ever mess around when you have a project going on!
  #98
Old 01-09-2014, 06:12 AM
Thanks Bill! If my back was up to it I could probably get done this weekend, but I'm not sure I can/will work that hard.
Glenn, the hoses for the dually are different cause they come out on the fiberglass fenders, so I got some from the junkyard for 20 bucks off the same truck I got the wheels.
  #99
Old 01-09-2014, 09:48 AM
Oh, for some reason I was thinking fuel lines?
Glad you found some! They are pretty tough even being old, I've had mine off and on a few times, LOL
  #100
Old 01-11-2014, 04:18 PM
I knocked off early today, back just is not feeling real good. I got my solid mount done for the ball and set the box on. I have to get a set of body bushings. The passengers side rear is sagging pretty good. Only one, but I'll change them all. A few more pics.
Here's the mount. It had the 3/4 steel across for the flip down ball mount. I put a piece of 1/2 inch plate between them for the ball and 3/8 angle under each side to tie them together. The angle is welded to the original 3/4 steel, the plate, and to the nut for reinforcement.
Here's a few pics of the box just sitting on. Not sure if I'll get anything done tomorrow, depends on how I am. Gotta go see the doc who did my first back surgery friday.
  #101
Old 01-11-2014, 04:24 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
Lookin good Darin. How was the 5" with the spare? Mine was a pita.
  #102
Old 01-11-2014, 04:31 PM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Getting closer Darin, looks real good.
  #103
Old 01-11-2014, 04:32 PM
Thanks Rick. I assume you mean the spare tire. I don't know, mine has been in the box for 10 years.
Thanks Kevin, gaining!
  #104
Old 01-11-2014, 05:00 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Looking good man! Very nice.
  #105
Old 01-11-2014, 05:17 PM
FI460's Avatar
Ahh. I wish I had a good spot to relocate mine. It's the stock spare and my exhaust barely cleared it. No way a 315/75 is going down there.
I havent had time to follow the build much. Have you had a chance to compare the 5" with the 4" exhaust tone?
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 11:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 11:01 AM
1939 Ford truck information 31hillard 1947 and Older Ford Trucks 23 09-15-2014 12:02 AM
Finally started my York Air today 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 39 12-15-2013 01:08 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 05:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
