My dually conversion, with some porn.. - Page 6 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #76
Old 01-04-2014, 08:01 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I dropped it and with about 12 gallons in it I disconnected the hoses off my pump for the aux tank and sucked it dry. I ordered a new sending unit and will mod it according to Jim's write up. My orginal sending unit fell apart, the one my nephew got me didn't work so I'm waiting on the new one.
  #77
Old 01-05-2014, 04:09 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I got the wheel bearings in, put the brake "t" in off my axle as it was better, put my big cover on, drilled out the spring hangers to 3/4 for my spring bolts, and installed the axle. It's all hooked up and done for the most part. I have a question, pics are included with it here.
The solid stud sticking through this hub, between the wheel studs you see, seems to be a brake drum locator. The drum on this side has slots in the stud holes, so the drum will turn without that stud in there. The other side, the drum has round holes, not slotted like the other, and I have no solid locator on that side. The drum can't turn though as the holes are round. I'm guessing that was a replacement drum at one point. You'll see what I mean in the pics. Am I ok like this? Is it the way it is supposed to be? Do I need one for the other side? Just want to make sure.
  #78
Old 01-05-2014, 04:46 PM
Another question. Anyone know where I can get a new vss pigtail? I checked riffraff and didn't see one unless I missed it. Searched here and didn't come up with crap. I broke one of the side clips so I should replace it.
  #79
Old 01-05-2014, 04:59 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Darin I got one from JEGS
  #80
Old 01-05-2014, 05:25 PM
Thanks Mike. I found it there and got one coming.
  #81
Old 01-05-2014, 06:17 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
The progress looks good Darin.
Rockauto has the VSS pigtail too for future reference. I think they might call it an ABS sensor or something though.
  #82
Old 01-05-2014, 08:35 PM
I didn't understand about the studs your talking about. On both my sides I have a stud that sticks out that the wheels line up to with a hole in the wheels.
  #83
Old 01-05-2014, 09:12 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Both of my duallys have a roll pin where the "locater" is in the first pic, that sticks out threw both wheels, and the inner wheel has a *** like that locater that fits into the hole in the drum that you can see in pic #3. The *** on the wheel is 1/4 turn off of where the roll pin will go threw the wheel. The roll pin "times" the wheels so the hand holes in the wheels aline. As long as the wheels fit tight/flat to the drums you will be fine. The drum with the slots where the studs fit threw must have been run loose as mine have just the round holes like your other one.
  #84
Old 01-05-2014, 11:15 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
That style locator for the drum may be something just on the first gen axles.
  #85
Old 01-06-2014, 06:19 AM
Thanks guys. Tom, I never thought about that drum getting egged out, but I guess it could have. The wheels fit tight to the drums and fit good on the wheel studs so I should be ok then.
  #86
Old 01-06-2014, 08:38 AM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I'm not sure if this was said or if I missed it somewhere Darin, are you going with a D60?
  #87
Old 01-06-2014, 09:04 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
The roll pin is to line up the valve stems so you can get to the inside one. That is the ONLY reason it is there.
I cut mine off and have Zero issues(I was not going to drill a hole in my Alcoa wheels and spacers)
  #88
Old 01-06-2014, 03:40 PM
Thanks for that info Brad.
Todd, I'm using my 50. Maybe someday I'll get a 60 under there, but my 50 is in good shape and will do me fine for now.
Here's one shot of the axle in the truck. I'm getting two tires, and a few odds n ends this week to finish it up. Couple more weekends and the dually conversion will be done. Spent a few hours shoveling out the shop again. Man, I can make a mess.
  #89
Old 01-06-2014, 03:42 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Holy leaf springs........ I think I'll keep my stock springs and run air bags. That has to ride like hell, especially when empty. LOL
  #90
Old 01-06-2014, 04:11 PM
WOW that is a stack of springs. What is that 10 plus the overload?
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 11:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 11:01 AM
Trucks Gone Wild At Slopoke Mudbog In Eastman Ga 460 FORD MAN Offroad & 4x4 24 10-07-2013 05:55 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 05:45 AM
Battery relocation question 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-27-2011 02:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
