My dually conversion, with some porn.. - Page 5 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #61
Old 01-03-2014, 06:25 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I got the tunnel done. It wasn't too bad to do. I 2 pieced it. I cut up in the firewall so high to get room it was easier to fit one for the upper then one for the lower. I tacked them in many places, then used body seam sealer over the edges. It turned out quite well I think.
I didn't do this just for the heck of it, I did it because it was what i wanted. If it was something that I didn't think I could do, or thought it wouldn't turn out good, I wouldn't have done it. I knew it was going to take some time and be kind of a pain. I kinda like doing this stuff though.
Here's a few pictures of the finished product.
Tomorrow I'm gonna work on the axle. My hub bearings didn't show up yet, but could be here tomorrow.
  #62
Old 01-03-2014, 06:30 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Looks good Darin! I took a lot more out of mine, and probably didn't need to, but I got all kinds of room in there now.
  #63
Old 01-03-2014, 06:33 PM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Looks good Darin.
  #64
Old 01-03-2014, 06:48 PM
Thanks guys! I've got at least 1/4 inch anywhere around it, and its only that close in one spot.
  #65
Old 01-03-2014, 07:01 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
That looks good Darin! That will make it a lot less of a headache to do what you want to do with the exhaust in the future too. I doubt you'll ever regret having tunneled it out.
  #66
Old 01-03-2014, 07:11 PM
ReBilld's Avatar
Quote:
I don't know what else he could do after this! LOL! He's already got a culvert in there for a DP! LOL!!!
  #67
Old 01-03-2014, 07:34 PM
Quote:
LOL! It almost looks like one when I lay it beside the 3 inch dp.
Thanks Nate! I don't see any reason I'll regret doing it. I had to do something as the dp was hitting the bellow. I figured if I'm gonna tunnel, I might as well make room for a big pipe! Now I don't have a cut up mess under there that I had from making room for the 3 inch either. Looks a lot better, makes me happy.
  #68
Old 01-03-2014, 08:01 PM
ReBilld's Avatar
My floor was split in two places at the pinch weld from where the 3" was put in before I bought the truck, and I made it worse pushing on it with the porta power trying to get the 3.5" in there, so I thought the same things as you....it's messed up anyway, so might as well tunnel it and do it right.
  #69
Old 01-03-2014, 08:42 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
How do you actually do it, start with a hole and use a saw zall? My firewall is a mess trying to clear that darn bellow. Nice job Darin!!
  #70
Old 01-03-2014, 09:07 PM
ReBilld's Avatar
Quote:
I used a cutting wheel on mine Glenn. A body saw would be ideal, but I don't have one.
  #71
Old 01-03-2014, 10:19 PM
That makes sense.
  #72
Old 01-04-2014, 06:21 AM
Thanks Glenn! That's what I used too, a cut off wheel and a sawzall combination. I cut a hole inside with a cutoff wheel first. Then I had to keep going up the firewall to make room, so the sawzall got involved. I absolutely couldn't go any higher on the outside edge of my hole, i'm into a dash bracket and some other thing on the inside. There are 4 more cuts on the top part of my hole on the firewall. I pushed the firewall back in more with them. I then covered them cuts with the upper part of my tunnel. A little seam sealer where I could and the same heat reflective stuff I used on the ac box put on the firewall.
I guarantee that dp was in and out at least 15 times between clearancing for and building it.
  #73
Old 01-04-2014, 06:35 PM
I got the new bearings on the gears and got them setup today. I didn't get quite as much done as I wanted, my granddaughter was around all day. I've got tomorrow and monday to work on it so I'll be ready to set the box on next weekend. It's supposed to be in the upper 30's or so, that'll work. Tomorrow and monday we are looking at -50 wind chills, so needless to say, I'll be in the shop.
My hub bearings showed up today so tomorrow I'll get those done and put the axle in the truck. Probably just piddle with a few little things tomorrow besides that.
  #74
Old 01-04-2014, 07:06 PM
Progress, can't wait to see it! Are you going to paint the box or have it done?
I'm waiting on a new fuel sending unit, that tank has been nothing but a PITA. I have thought about putting a stock one in, LOL
  #75
Old 01-04-2014, 07:28 PM
I hear ya! I'm getting it painted. Won't be til summer though. I want it to look good, and I'm really not a body man. If I get after it pretty good I could probably have the dually part done next weekend. We'll see how it goes. Still gotta get 2 more tires.
That tank has been a pain. So you gotta drop it again? I really couldn't afford to, or have time to, put one in mine right now with all the other things I have going on so I didn't. I don't think I ever will either. Although it would be nice, I don't go that far from home, and I've got an easy place to stop at for fuel when I go to Pierre to the race track. I hope you get it working Glenn.
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 11:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 11:01 AM
Trucks Gone Wild At Slopoke Mudbog In Eastman Ga 460 FORD MAN Offroad & 4x4 24 10-07-2013 05:55 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 05:45 AM
Battery relocation question 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-27-2011 02:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
