My dually conversion, with some porn.. - Page 2 - Ford Truck Enthusiasts Forums
Old 12-30-2013, 10:27 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is online now
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Will you be a putting on a dually bead or a flat bed?
What gear ratio are you going with?
Old 12-30-2013, 10:29 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Looks awesome Darin. Looking forward to seeing it done!
Old 12-30-2013, 10:34 PM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Quote:
Originally Posted by Diesel_Brad View Post
If you run Factory 4wd rims(5.35 offset) you can run 265s no problem
2wd rims are only 5.00 offset
I didn't know they made different offset wheels for a dually. I will check my and if they are 5.00 I will start looking for some 4x4 wheels. I don't like running the spacer. I could probably get away with out them until I put a load on it, they don't touch it just close.
Old 12-30-2013, 10:37 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Van is different again. they are 5.15. Dam ford and changing things
You can look at GM and dodge wheels too.
I am running dodge offset (alcoa) Aluminum wheels on the Inside rears. I just had to have the center machined out to fit over the hub. I forget what offset they were but it was pretty good
This is 2 dodge wheels back to back with a 2" spacer and 315s(just because I got impatient and wanted to see what dual 315s looked like)
Old 12-30-2013, 10:46 PM
dougbrown's Avatar
dougbrown dougbrown is offline
dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.dougbrown has a very good reputation on FTE.
Those 315 look bad a$$ on there. If I had a wide hip girl I'd look into 305 or 315's. Also what your frame coat in? Looks so smooth and like factory new under coating.
Old 12-31-2013, 06:18 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Thanks guys. Those 315's do look real nice.
Kevin, I'm running some factory steel wheels for now so I need to use the 2 inch spacers to make them work. We've got different backspacing wheels for sure, cause I know I'd not have enough clearance with a 1/4 inch spacer. Well, they may clear, but would be soo close I couldn't put a trailer on for sure. With the 2 inchers I should have around 1 1/2 inches between the tires, just like the skinny stock tires are now I got with the wheels. That number may be a little bigger. The 265's are 2 inches wider on my factory aluminum wheels, but I think the steels are an inch narrower so the sidewalls will probably suck in a little making them a hair narrower. I've got simulators to use on the wheels, someday I'd like to get some nicer wheels but these will work ok for now. I bought the wheels, simulators, and lug nuts for 200 bucks so that was a good way to save some cash for now.
Phil, I bought a dually bed this fall. It is already red, however, not the right color red so I'll get it painted. That won't get done until summer sometime when I build up some more cash flow. I switched axles with someone to get 4.10's a little over a year ago, that is what's staying in here.
Old 12-31-2013, 07:02 AM
BEEMAC BEEMAC is offline
BEEMAC is starting off with a positive reputation.
So I have a 95 F250 I been considering turning into a DRW. I bought a 92 DRW axle from an F350 with 3.55 gears in it. My problem is the spring perch on the axle is shorter than my springs. Do I really have to adjust my spring hangers on my truck or should I be looking for a different axle?
Old 12-31-2013, 07:08 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Looking good Darin! Keep the truck **** coming!
Old 12-31-2013, 08:18 AM
Quote:
That is all sandblasted, 1.25 gallons of POR15, then top coated with 1 gallon of Valspar Low Glare Black
My 97 CCSB build - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old 12-31-2013, 09:56 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Quote:
What do you mean by shorter? Closer together? If so you got a cab and chassis rear axle. You need an axle from a truck that left the factory with a bed installed. Look at this thread for measurments. http://www.ford-trucks.com/forums/12...l#post13216938
Old 12-31-2013, 07:25 PM
Thanks Nate!
Beemac, what Tom said above is what you need to know.
I started the downpipe this afternoon. I had to do a pretty good amount of firewall/floor removal here to get that 4 inch sucker in. That was pretty much a pita. I'm at the point I don't need to cut anymore, and have the flange and elbow right off the turbo made. I cut the flange end off just a few inches after the bend on the dp. Then cut a "V" in the inside of the bend and made it a sharper bend, as it wasn't sharp enough to get down where I needed it to. Tomorrow should be easier, I just need to finish piecing the dp together and hang the exhaust. I have to pick up some metal the end of the week to fix the hole in the floor, I'm out, so that won't get done yet.
I'll put some pics of the DP and hole tomorrow.
Old 12-31-2013, 10:46 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Man Darin, your doing a lot of work and its looking good!
  #28
Old 01-01-2014, 05:59 AM
Thanks Glenn! I want to have this done in a 2-3 weeks if I can, so I'm gonna stay after it fairly good. Lots of other stuff to do this winter.
Talked with Bill last night and he just used a cut up piece of body panel off a parts truck for his floor piece. We have plenty of parts cars/trucks in behind the shop so I should be able to get something there to use.
I still need to get some 1/2 inch metal. I'm getting rid of the hide-a-ball that was in my pickup and putting a solid one in. I'll use the bracket that is there for the hide-a-ball and modify it for the solid mount.
  #29
Old 01-01-2014, 09:54 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Sucks your so far away.im gonna cut mine off my frrame when i do the new bed..id give it to you lol...its a CHUNK o steel!!!
  #30
Old 01-01-2014, 10:24 AM
Darin, what kind of hide a ball do you have? I have a B&W turn over in the 97 that I really like. I put one in the 96 crewcab also. The 96 C&C has a fold down type that someone put in wrong, it folds from front to back instead of side to side. You get slack in the ball that way. I'm going to have to cut it out and either put a solid one in with a door to cover it, or put the fold down in under the the door as it sets way to high now.
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 11:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 11:01 AM
1939 Ford truck information 31hillard 1947 and Older Ford Trucks 23 09-15-2014 12:02 AM
Finally started my York Air today 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 39 12-15-2013 01:08 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 05:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
