My dually conversion, with some porn.. - Page 12 - Ford Truck Enthusiasts Forums
  #166
Old 01-21-2014, 09:31 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Lol..todd...keep up the good work.
  #167
Old 01-22-2014, 08:53 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I've named a few that too Todd, LOL
  #168
Old 01-22-2014, 08:58 AM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
I think we all have!
  #169
Old 01-22-2014, 12:05 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.
My friends in high school called my '96 Great White. I call our '07 Fusion "The Little Blue Sleigh" because it slides around on the snow so bad. My '97 PSD does not have a name yet.
  #170
Old 01-25-2014, 05:45 AM
dizzyfingers03's Avatar
dizzyfingers03 dizzyfingers03 is offline
dizzyfingers03 is gaining momentum as a positive member of FTE.
For some reason, I never posted so I was getting updates from your thread. I just had a chance to get caught up this morning. The dually 4WD EC really does look sharp. I hope it performs well for you. Did I read you still had the original D50 up front? If so, I'm curious how that rides when you get the truck on the road.
  #171
Old 01-25-2014, 05:56 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Thanks Nick! Yes, I still have the original D50. I'll be plugging away at the truck today again. I'll be sure to post up how it all works when I'm done and putting it to use.
  #172
Old 01-25-2014, 10:24 AM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
The truck is looking good Darin. I have always thaught that an excab 4X4 dually would be neat. For what it's worth check your rims for the Acuride number on them. The 4X4 rim should be a 29316, the 4X2 will have 29315. the 4X2 rim will work, but the off set is shallower, and the stock 235/85-16 will be close to touching with the 4X2 rims.
  #173
Old 01-25-2014, 10:34 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
Good info Tom! I tried to rep you. I must have 4x4 rims then, because I have 235/85 tires on mine and there is at least 1 1/2" between the tires on the duals. I wonder if 265/75s would work without spacers?
  #174
Old 01-25-2014, 10:49 AM
Thanks for trying Bill. My Ebay special has a miss match of rims on it. One side has the 29316 rims on it, and has about 1 1/2-2 inches between the tires. the other side ther is only about 1/2-3/4 inch between the tires, and the outer rim is the 29315. I never thaught to look for the number on the inner rim when it was off.
  #175
Old 01-25-2014, 11:06 AM
ReBilld's Avatar
I'd like to go to 265s when it's time to buy tires, but I don't want to use spacers. By looking at space between my 235/85s, I think 265/75s may work without spacers between the wheels, but I don't want to buy 265 tires without knowing for sure.
  #176
Old 01-25-2014, 07:12 PM
My wheels came off a 4x2 truck, so they must be the 29315's. Good info Tom. Thanks for the comments too!
Bill, if you only have 1 1/2 inches now, I don't think you will have enough for the 265's without spacers. You may make it with a 1/4 inch spacer, but it will be pretty tight, especially with a load on. I think the 265's are about 1 1/2 inches wider than the 235's. So that would be 3/4 more on each side and put you touching without spacers. The stock 215's that were on these wheels are 2 inches narrower than the 265's. The tires on mine now where the tread ends sits straight down from the edge of the fender, so the sidewall does stick outside of it a little bit. As you know, this is with 2 inch spacers, and 1 1/2 inches between the tires. I don't know how much I like that, but its sure not a deal breaker.
I got the body and box mounted, rear visor back on and remounted the step bars this morning. I put the plastic liner back in it for now that came with it too. It's in good shape, the inside of the box looks almost like new, it covers up the different color red, so it went back in.
After dinner I needed to put a fuel pump on my 76, it was leaking almost a steady stream of gas out the weephole. Figured I'd change the oil too. Put the new pump on, fired it up, and it died. Messed with it for a while, switched lines around, removed it, inspected, and reinstalled with no luck. 20 minute fuel pump job took 3 hours and the truck's still sitting in the shop. I think I made up a few new cuss words, I was getting so frustrated. Had a good morning working on the red truck, then after dinner went to he!! in a handbasket, all over a flippin fuel pump. I happen to have an inline electric pump from a demolition car I built once, and a fuel pump block off plate on a motor in the shop. So, tomorrow, screw that 26 dollar napa pump.
  #177
Old 01-25-2014, 07:29 PM
ReBilld's Avatar
LOL!! It's the little things that get ya isn't it!
  #178
Old 01-25-2014, 07:34 PM
Yes it is! I was so frickin mad! I don't even want to try another one!
  #179
Old 01-25-2014, 07:38 PM
ReBilld's Avatar
I went through the same thing on a '76 F700 dump truck I had. Finally went and got an electric in line pump too. I was ready to burn that SOB to the ground....and that was the day I brought it home! LOL!!!
  #180
Old 01-25-2014, 09:11 PM
You must have eaten to much dinner and desert Darin! LOL
On Board Air is finally done 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 46 03-29-2015 10:07 PM
Battery relocation done. Coolant filter done with pics. York prep started. 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 94 11-27-2014 10:01 AM
1939 Ford truck information 31hillard 1947 and Older Ford Trucks 23 09-14-2014 11:02 PM
Finally started my York Air today 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 39 12-15-2013 12:08 PM
alternator, double tensioner, ex. manifold, starter, etc. all done thread. Few pics added 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 89 06-25-2012 04:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
