power steering issues
Old 12-30-2013, 02:32 PM
jccapri's Avatar
jccapri
jccapri is offline
Last night while backing my trailer in my yard I turn the wheel real hard to the left heard a moan then a pop and I lost all power steering no power steering fluid leaking in the brakes still work good it just doesn't want to turn the tires unless you're moving or wrapping up the motor did I blow a seal in the power steering pump or is there a another valve somewhere
Old 12-30-2013, 02:52 PM
clem1226's Avatar
clem1226
clem1226 is offline
check to see in the high pressure line is still connected at the pump, it has a little C clip that retains the hose in the fitting that wears over time and then the hose blows out. If that has happened ( pretty common) the only solution is to replace the hose. It is about $50 ish iirc at most parts stores.
Old 12-30-2013, 02:58 PM
jccapri's Avatar
jccapri
jccapri is offline
Yeah if that hose comes undone wouldn't it be leaking fluid out. I have no fluid leak And at high rpm I have power steering
Old 01-16-2014, 03:33 AM
jccapri's Avatar
jccapri
jccapri is offline
well got the power steering done o'reilly's pump and mobil 1 synthetic fluid all good now. thanks guy's
JIM ROLAND
15
07-16-2011 05:48 PM
74baja
05-04-2009 06:20 PM
rbenton
1983 - 2012 Ranger & B-Series
09-29-2005 03:23 PM
Quick Reply: power steering issues
