Blinkers flash fast when brakes applied
Old 12-30-2013, 02:05 PM
2inthewind's Avatar
2inthewind
2inthewind is offline
Third brake light stays on and flashes when turn signals activated. Apply blinkers and cruise control disengages. Checked fuses and found a 10 amper blown to the right rear brake light, replaced, no fix there. Any ideas? Maybe the BOO switch? All other lights work fine, no problems with multi-function switch. HELP! 2007 F-150 King Ranch. P.S. Replaced brake on-off switch with a known good one...No fix there.
Last edited by 2inthewind; 01-03-2014 at 10:10 PM. Reason: Error in thread, (Brakes disengage cruise)
Old 12-30-2013, 06:59 PM
1saxman's Avatar
1saxman
1saxman is offline
Speed control always cancels when the brakes are applied. Think about it.
Old 01-03-2014, 11:14 AM
2inthewind's Avatar
2inthewind
correction
Sorry about that 1saxman, I mean cruise control disengages when turn signal applied.
Old 01-04-2014, 12:48 PM
fordfool2's Avatar
fordfool2
fordfool2 is offline
You have a filament crossed in one of your rear taillights. Replace the bad (or both) rear taillights and this should resolve your problem.
Old 01-05-2014, 10:57 AM
2inthewind's Avatar
2inthewind
Broken filaments, rear brake light?
Thank you, Fordfool2 - Ill replace them and let you know.
Imadabbler
08-17-2014 01:12 PM
blake 7.3L
08-07-2008 11:31 AM
Pat M
1983 - 2012 Ranger & B-Series
02-01-2008 04:14 PM
cadman
01-24-2007 06:13 PM
mikebon08
08-12-2005 01:17 PM
Quick Reply: Blinkers flash fast when brakes applied
