4 wheel fun....gearing is awesome!!! - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 12-30-2013, 01:24 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
So yesterday on my way back from the store I pulled into a large empty field. I wanted to engage the 4 wheel drive to give the transfer case some use and make sure everything was working properly. I don't hardly use my 4 wheel drive....I think I have actually needed it twice in the past year since I bought the truck and it was not because I was stuck but more so to keep from tire spin and tearing up my friends yard lol.
The past 2 times I used it I used 4WH....I have not used the low at all. Well I pulled into this field and engaged the high side and just drove around did some big figure 8's just to make sure everything was in order. I climbed a few hills just to play.
Then I switched to the low and the gearing is crazy......just for fun I stabbed the throttle and holy crap.....this truck surprised the hell outta me. The gearing is so low and the engine makes such good power it pined me in the seat............lots of fun
Old 12-31-2013, 07:51 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Yup, and your transfer case has like 2.6 or 2.9:1 gearing in LOW - which means if you have, for example, a 3.73 rear/front gearing, putting in LOW gives you a 10:1 gear.
Of course, you are severely limited on high speed travel
Old 03-17-2014, 11:13 AM
troverman's Avatar
troverman troverman is online now
troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.troverman has a great reputation on FTE.
Low range reduction is 2.72:1 in low, which is not bad for a modern 4x4 (although the NVG 271 / 273 t-cases in these things have been around for a long time)...but be advised you total reduction is based upon three things...the ratio of your transmission's 1st gear, the transfer low range ratio, and your axle ratio. Fortunately the 6-speed transmission in these trucks has a nice short 1st gear ratio. But a Jeep Wrangler Rubicon has a 4:1 low ratio gear, etc.
4wd not engaging 97 expedition ctown2 1997-2006 Expedition & Navigator 28 01-22-2017 06:01 PM
Had some fun, now my AOD is making noise... 351Cleveland C4 1987 - 1996 F150 & Larger F-Series Trucks 0 01-07-2016 07:20 PM
2005 F350 4x4 problems and no reverse FordCamping 1999 to 2016 Super Duty 10 08-10-2012 09:42 PM
ZF-6: Failure to Engage (long) SailCO26 1999 - 2003 7.3L Power Stroke Diesel 25 06-04-2010 09:41 AM
93 Explorer A4LD Auto Tran-No Reverse charles.bunch Clutch, Transmission, Differential, Axle & Transfer Case 0 03-11-2010 10:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
