48 F2 radiator and gas tank question
Old 12-30-2013, 07:36 AM
flushedup's Avatar
flushedup
flushedup is offline
I'm to the point where I need to get a radiator and a gas tank. I'm using a 351w with a C6. Not sure what size radiator to use that will fit in the original location and where to get one. The gas tank I've seen several choices I want it out of the cab and plan on putting it behind the rear end but unsure which one to get. Any input would be great Dennis
Old 12-30-2013, 08:04 AM
toby tough's Avatar
toby tough
toby tough is offline
I'm no expert but I think a lot of the folks use a Mustang tank when relocating it.There are some issues with which sender to use I think, it has to be compatible with your gauge. As far as the rad. I dunno. I,m not changing anything on my truck so I haven't researched it. Might try the search bar for an old thread on that. Iv'e gotten a lot of info from there. I'm sure one of the more experienced guy will be along soon.
Old 12-30-2013, 08:53 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
As far as the radiator, I'm using the one that came out of my 79 ford Bronco. It is matched to the motor that I put in my 48F1, a former 351M. I had to make a new mount but it works great.
______________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
Old 12-30-2013, 09:06 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,450 Likes on 1,397 Posts
Check out Home - Classic Haulers F-1 Parts They will have replacement radiators that fit the stock rad mount which will work perfect for your application, accepting a modern pressure cap and with trans cooler installed. They also have rear mount gas tanks you can install behind the rear axle without any frame modifications. Good folks to deal with, too.
Old 12-30-2013, 02:05 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Dennis
We used a '70 Mustang tank out back under the bed - 22 gallons is nice. We used a racing radiator off of Summit for our 351W.
Good luck over there.
Ben in Austin
1950 F1
Old 12-30-2013, 09:24 PM
dmack91's Avatar
dmack91
dmack91 is offline
I bought an aluminum rad off of Ebay. Made by Champion. I have seen them for around $200-250. Direct bolt-in and they have different inlet/outlet locations depending on the engine you are using.
Here is one:
PART #CC 4252 - Oscar's Radiators
49 ford fire truck
01-09-2015 05:59 PM
HILLBILLY BOB
Ford Truck Parts for Sale
12-16-2014 11:43 PM
Bikewrench
49
07-17-2006 02:03 PM
joshsombo
01-31-2006 05:04 AM
dongc1
07-18-2004 05:27 AM
Quick Reply: 48 F2 radiator and gas tank question
