Improving Steering with OEM suspension - Page 2 - Ford Truck Enthusiasts Forums
Old 07-09-2014, 10:18 AM
FP's Avatar
FP FP is offline
FP has a good reputation on FTE.FP has a good reputation on FTE.FP has a good reputation on FTE.
Thanks guys. AX, yes I realize there are many variables that can complicate the job. My truck is all stock w/ three on the tree, but must say it's pretty clean in and out. That said, it doesn't mean it wont have some rusted bolts or nuts, or fasteners. I am having a old car mechanic do the job. I won't take on this level of mechanical work. I'm sure he will have to improvise at times. I was just trying to get a rough idea how long it might take given the condition of the truck. I bought all new hardware with the kit from midfifty.
Thanks again.
FP
Old 07-09-2014, 01:11 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
A good mechanic working alone, that understands what needs to be done, is familiar with old Fords, using all new parts, with the proper tools and a lift, working carefully, without complications:
1 hr to remove inner fender panel.
2 hrs to remove OEM steering column and box.
1 hr to mount new box, pitman arm and rebuild/install drag link.
2-3 hrs to cut off, modify, replace steering column. + 1hr if adding horn button conversion kit.
2-3 hrs to mount power steering pump, run and bleed lines.
2 hrs to replace inner fender, check everything.
Total 10-12 hrs. would be a fair estimate.
No improvisation should be required or desirable. If improved something was done wrong, it is almost completely bolt in.
Note: do not discard cut off OEM box! Mid Fifty will buy it from you.
Old 07-09-2014, 01:13 PM
FP's Avatar
FP FP is offline
Ah thanks. That's what he quoted me.
Old 07-09-2014, 01:56 PM
AXracer's Avatar
Wish you were closer, I'd do it for you.
Old 07-09-2014, 02:53 PM
FP's Avatar
FP FP is offline
Quote:
Dang, thanks...
Old 07-09-2014, 10:11 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
I think they only pay$25.00 for each box, I'll pay more than that for old steering boxes
Old 07-10-2014, 08:25 AM
Steve's Avatar
Steve Steve is offline
Steve is gaining momentum as a positive member of FTE.Steve is gaining momentum as a positive member of FTE.
We had a similar thread going last week. One question I have on this subject is if one uses the manual Toyota box, would the faster ratio as compared to the stock box result in "harder" steering effort?
Old 07-12-2014, 08:09 PM
turnrjr turnrjr is offline
turnrjr is starting off with a positive reputation.
FP if you are keeping the stock column shifter and are converting the steering box to a Toyota, the job is more involved and will take quite a bit longer. There is not enough room to utilize a universal joint between the new steering box and the column shifter arm assembly. You need to use a straight solid coupler. I believe I got mine from CPP. The shifter arm assembly needs to be moved higher on the stock column which requires shortening of the shifter tube. Once the shifter arm assembly is moved, the shifter arms are no longer positioned correctly for the rods to the transmission and the higher one can't swing without hitting the firewall. The arms must be cut, repositioned and re-welded. The cut off stock column also needs a new bottom support to be fabricated. I was not comfortable mounting it to the thin split pieces that cover the opening in the floor so I fabricated a heavier one piece cover. You will also need a means of centering the steering shaft in the cutoff steering column. I used an oil-lite bronze bushing purchased from fastenal. A standard lip seal is available to insert in the bottom of the cutoff column to keep crud out. I found there is not much information available here or elsewhere for this conversion. Hope this helps.
Old 07-13-2014, 09:27 AM
Steve's Avatar
Why does the shifter assembly have to be moved higher?
Old 07-14-2014, 04:44 AM
After the Toyota steering box is mounted, the stock column and steering shaft is cut to adapt to the input shaft on the steering box. The column shifter assembly that is originally mounted at the lower end of the stock column is now displaced by the shortened column.
Old 07-15-2014, 09:43 AM
Steve's Avatar
53-56 Ford F100 truck Toyota Power Steering Kit for straight axle
This kit mentions that it is used with a stock column. Looks good but expensive.
Old 07-15-2014, 10:53 AM
FP's Avatar
FP FP is offline
I believe this is the one I bought.
  #28
Old 07-15-2014, 11:18 AM
Steve's Avatar
Mine is a column shift as well. I have a manual Toy box in good shape, but am having some second thoughts:
1) Not sure if a manual box will be harder to steer than stock due to faster ratio.
2) Sounds like quite a bit of extra work is involved since I want to retain the stock shifting (as pointed out by Turnrjr). I guess it can be done though.
FP- Are you planning to retain the three on the tree?
  #29
Old 07-15-2014, 11:21 AM
AXracer's Avatar
The only extra parts shown is a rag joint shaft connector. You need more than that to convert the stock column to re-use it: For floor shift column; Lower shaft centering bushing, lower floor mount, floor inspection plate cover for Toyota conversion, horn button switch conversion or remote push button horn switch, horn relay. For column shift: all of the above plus straight slip joint connector, shortened shift tube, reworked shift arm(s), reworked shift linkage.
  #30
Old 07-15-2014, 03:43 PM
FP's Avatar
FP FP is offline
Yep, I don't have the list with me right now, but there was a long list of additional parts needed.
Steering Damper? dotcentral 1967 - 1972 F-100 & Larger F-Series Trucks 11 07-07-2014 10:29 AM
Touchy Steering CLARK3234 Excursion - King of SUVs 5 05-16-2014 03:03 PM
Sway bar & air bags abranz Excursion - King of SUVs 5 04-25-2013 07:27 AM
Suspension upgrades for F250 1971? Gf2501 1967 - 1972 F-100 & Larger F-Series Trucks 4 12-24-2011 03:15 AM
Fridge suspension and steering leewiffen 1957 - 1960 F100 & Larger F-Series Trucks 5 11-09-2011 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
