has anyone welded the seam - Ford Truck Enthusiasts Forums
Old 12-29-2013, 11:37 PM
dav54effie's Avatar
dav54effie dav54effie is offline
dav54effie has a good reputation on FTE.dav54effie has a good reputation on FTE.
im new to the forum but ive been a stalker for a while. ive got a 54 f100 and i have been messing with it a bit and stuff. im wanting it to be a driver and not a show truck bc i dont wanna put all that effort and not get to enjoy it. one of the things i have been considering is welding up the seams, like on the back of the cab above the window. has anyone on here done that and if so, can you post some pics or point me to a thread about it? thanks for any help!
Old 12-30-2013, 04:50 AM
Aus56's Avatar
Aus56 Aus56 is offline
Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.Aus56 has a very good reputation on FTE.
Hello, I am not a body man, but that seam is a pretty solid join I would think. Why not just lead the seam, it will work fine and be a lot simpler. Customisers have leaded seams for years. It is durable, not like fibreglass or bog.
Old 12-30-2013, 06:35 AM
Giesterfarher™'s Avatar
Giesterfarher™ Giesterfarher™ is offline
Giesterfarher™ is starting off with a positive reputation.
Quote:
Mine was welded by the PO. It came out really nice. I'll try and get some pics later today, weather permitting. If you go to my garage, there is one pic that kinda shows it. The one of it on the trailer. You might be able see it well enough.
Old 12-30-2013, 08:44 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Depends on how muck experience you have welding sheet metal. There is a significant risk of warping the daylights out of it if done incorrectly and with the flange type seam there is no way to repair it. Seam sealer makes a lot more sense.
Old 12-30-2013, 08:53 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Why?? What would be gained?? Clean it well and use seam sealer, JMHO.
Old 12-30-2013, 10:21 AM
dav54effie's Avatar
Quote:
aus, what is bog?
Quote:
i would appreciate that so much, i want the smoothness of that. i dont really like the "break" of the seam in the lines of the truck cab. thank you
Quote:
im not wanting to seal it, i am wanting to weld it up, smooth it out and be rid of the seam. to me, its not something i want to keep and it is purely cosmetic. i guess you can call me a darksider. lol but thats what i want!
Old 12-30-2013, 01:05 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Clean the seam well, a wire brush wheel on a drill motor works well. Once you have clean, bare metal showing on both sides of the seam (and into the seam itself) then you are ready to weld. I use a MIG with gas shielding. I lay out a number of tack welds about every 2 inches or so, let the metal cool and then repeat until the seam is all closed. There is a lot of metal where the seam comes together so not too much chance for warpage unless you really put a lot of heat into the weld...it can be done if you try to weld the whole seam at once though. I have seen these seams welded at only a few places along the length of the seam and then filled with panel adhesive to complete the fill...this seems to work just as long as you leave enough room above the fill to cover the seam with body filler to sand flash prior to priming and paint.
Old 12-30-2013, 05:24 PM
Aus56's Avatar
Dav54effie, bog is simply your everyday plastic body filler that you would be familiar with.
This Holden has had the seams between the rear guards and the body shell filled. Lead wiping has been used to do this for decades and gives a far stronger and durable result than fibreglass or body filler. It is pretty straightforward to do, and can be taken out readily if the guard needs to be taken off for repair.
I appreciate that you are not likely to take the top of your cab off for repair. It just seems to me that with a seam as solid as that one on your cab, the lead is easier to do than welding and is not likely to fail due to flexing.
Old 12-30-2013, 06:34 PM
71mach351's Avatar
71mach351 71mach351 is offline
71mach351 is starting off with a positive reputation.
I welded mine. I like the look.
URL=http://s184.photobucket.com/user/71mach351/media/56%20f100/DSCN2659.jpg.html][/URL]
Old 12-30-2013, 06:59 PM
+1 on that. Lead filler will take less than half the time and is easily reversible if needed.
Plus, no matter how slow you weld the seam, the weld metal WILL distort (Shrink) causing a depression right at the edge of the heat affected zone. You have to get the metal hot enough to melt in order for the deposited metal to penetrate. When it cools, it shrinks. It's just the nature of welding steel. This shrinkage requires grinding, then body filler. Or just excessive grinding, (Cheating LOL) which would weaken the joint at the edge of the weld, (Knife Edge, thin spots, etc.) not to mention if you slip up with the grinder you're back to body filler again to feather out low spots you made with the grinder.
The other option is a massive amount of time with a hammer and dolly peening out the weld zone/parent metal boundry. Expert level metal finishing for those allergic to lead and plastic.
The PO that did mine used the Mig weld, grind the weld more or less flush with the parent metal, then fill with plastic method. Like I said, it came out very nice, but if it was me, I'd have gone the lead route. And I'm a 30+ year veteran welder. I weld sheetmetal everyday for a living.
And you just never know when some dummy is going to drop something heavy on your roof and oil can it.
Old 12-30-2013, 07:03 PM
Quote:
URL=http://s184.photobucket.com/user/71mach351/media/56%20f100/DSCN2659.jpg.html][/url]
Thanks,71mach351! Now I don't have to go out in the cold and wind to take pics of mine!
Very nice job too.
Old 12-30-2013, 10:34 PM
dav54effie's Avatar
thats exactly what i am wanting to do! i really like the way that looks, sooth and clean. you just did spot welds all along it?
Old 12-31-2013, 11:02 AM
71mach351's Avatar
I welded the entire seam, took a grinder to it , then body filler. Lots of block sanding and epoxy primer. I also did the cowl seams and welded in the vent screws on the passenger side. It gives that area a nice smooth look.
Old 12-31-2013, 12:20 PM
dav54effie's Avatar
Ok. I messed with it a little last night and it turned out not to bad. The reason I'm not doing lead is bc I don't have all the supplies for that and I have a welding machine and I have done a few patches on the truck already so I've got a little practice. But what I did to it last night would take just a little bit of filler to smooth out.
Old 12-31-2013, 12:53 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
Just a question about the lead but I thought these new paint and primers wouldn't adhere well to it?Even the old cars it seemed like that was the first place to go.
Seam in back of cab To fill or not fill? Last chance 53 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 10-10-2016 09:33 AM
1975 f100 hood question axidjw 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-08-2016 07:23 AM
roof seam DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-29-2014 05:48 PM
filling seams on outside of bed chris66 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-14-2013 09:00 PM
filling and sealing the cab seam Marty Smilt 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-02-2010 01:41 PM
Tags
f100, how to, seam, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
