has anyone welded the seam - Page 2 - Ford Truck Enthusiasts Forums
Old 12-31-2013, 05:09 PM
TireDood's Avatar
TireDood TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
Quote:
Originally Posted by Olweldinrig View Post
Just a question about the lead but I thought these new paint and primers wouldn't adhere well to it?Even the old cars it seemed like that was the first place to go.
Eastwood has lead-free body solder that claims to work well with modern paint. I've never used it, but I have always been very happy with anything purchase from Eastwood.
Old 01-02-2014, 11:24 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Look at the photo series "details, details" to see the start of welding up the seam and the finished work on Snakebit. Personally I would lay a length of 1/6" tig welding rod in the seam so as to not need as much heat and filler wire, especially if welding with MIG. Note how they are doing a seires of tack welds a distance apart rather than a continuous bead. They may look like a continuous bead in the picture, but they are a series of short overlapping tacks.
Wheels Of Dreams Project - Follow The Build
I highly recommend using 0.023 ESAB Easy Grind wire for MIG. See my welding tutorial:
http://www.ford-trucks.com/forums/11...-practice.html
Old 01-02-2014, 12:41 PM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
I found my seam to be completely rusted out... the PO filled the seam. I haven't sanded it down to see what was used to repair. I'm planning on checking it and if it's just bondo, I will need to weld it.
Old 01-02-2014, 06:59 PM
clintonvillian clintonvillian is offline
clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.
Ax, or anyone else....
Did you all notice the welding on the snakebit truck. Looks like they welded the drip rail over the door edge, Wonder why they didn't just drill out the spot welds???
Old 01-02-2014, 09:06 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I filled all the seams on my panel with a mig then filled with body filler. I like the look.
Old 01-03-2014, 12:16 AM
AXracer's Avatar
What spot welds are you referring to?
Removing the rain gutter is a complex job, about 4 layers of metal come together there. If you cut the gutter off there will be a gap that must be repaired.
Old 01-03-2014, 12:42 AM
dav54effie's Avatar
dav54effie dav54effie is offline
dav54effie has a good reputation on FTE.dav54effie has a good reputation on FTE.
ive seen of one of the many car shows where they cut a couple inches of drip rail then welded it, cut, weld, cut, weld. you get the picture. came out nice. im considering it for my truck. depends on how bored i get! lol
Old 01-03-2014, 11:35 AM
AXracer's Avatar
Quote:
Right way to do it, if you cut the entire rail off at once the roof skin will come free, and keeping alignment will be difficult. When you cut off the rail, there will be a gap between the roof skin and the cab sides that will need to be filled and the inner support panel will need to be reattached.
Old 01-03-2014, 11:47 AM
Isn't that only above the windshield? Arent the side rails individual pieces just spot welded to the upper door opening?
Old 01-03-2014, 05:31 PM
das54's Avatar
das54 das54 is online now
das54 has a good reputation on FTE.das54 has a good reputation on FTE.
Quote:
Originally Posted by AXracer View Post
Of all the custom work on this truck I think the "fender makeover" is likely the most practical because moving the front axle forward 5 inches will greatly improve the front to rear weight ratio and I gota think the improvement in handling will be huge. I really wish I had done this.
Old 01-03-2014, 06:51 PM
AXracer's Avatar
It improves the visual balance as well.
The roof has a flange is spot welded to the gutter at the inside bottom under the sealer. when you cut the gutter away the roof is no longer attached.
Old 06-07-2014, 11:31 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Anybody know where to get ESAB Easygrind .023? I can't seem to find it in any of the normal sources.
The welding the new metal patch panel to the old metal on the floorpan is giving me a fit. Any suggestions or tips? AX, I have been through your tutorials. Maybe I missed something?
  #28
Old 06-07-2014, 04:05 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
I ordered mine online from weldingsupply.com
https://weldingsupply.com/cgi-bin/ei...810:OR:130PS43
  #29
Old 06-07-2014, 05:11 PM
AXracer's Avatar
The 0.023 is only available in 11# (8") spools now. The 0.030 is still available in 2# spools while supplies last. If your welder only handles the small spools, I'd order ample supply of the 0.030 IMMEDIATELY. Even the heavier wire in Easy Grind is better than any other wire for sheetmetal and general purpose, so stock up while you can.
  #30
Old 06-07-2014, 05:21 PM
AXracer's Avatar
"giving me fits" is not a welding term I understand (well actually I do understand it, I just can't tell you how to fix it!) , so please be specific as to the problems you're having, the machine, type shielding gas (including regulator/flow meter setting) and wire you're using, and I'll try to help. Did you read the most recent installment on how to make and weld a butt seam in sheet metal? Start a new topic so it doesn't get lost and/or PM me.
Seam in back of cab To fill or not fill? Last chance 53 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 10-10-2016 10:33 AM
1975 f100 hood question axidjw 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-08-2016 08:23 AM
roof seam DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-29-2014 06:48 PM
filling seams on outside of bed chris66 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-14-2013 10:00 PM
filling and sealing the cab seam Marty Smilt 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-02-2010 02:41 PM
Tags
f100, how to, seam, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
