Need help diagnosing Ford 9" axle noise. - Ford Truck Enthusiasts Forums
Old 12-29-2013, 10:24 PM
Ste14mi Ste14mi is offline
Ste14mi is starting off with a positive reputation.
I've been making steady progress on my 1950 F3 over the past couple of months, to whit:
- Converted from 6 to 12 volts with GM alternator.
- Refreshed all engine components and got engine running for first time in 20 years.
- Converted front hubs to disc brakes from Speedway.
- Installed power brake system from CPP.
- Installed 1999 Dodge RAM wheels with new Cooper 225/75x16 tires.
- New shock absorbers.
- General cleanup and paint of chassis back as far as the start of the bed.
- Removal of original F3 rear axle.
I'm now in the midst of rebuilding a 1959 Ford F100 9" rear (3.50 ratio, 28 spline) to put under the truck. Have replaced axle bearings and seals and am working on pinion bearings. While reviewing what needed to be done on the axle, I discovered that there is a ticking/clunking sound that happens when the left axle is rotated (but not the right) leading me to think that it is coming from the differential spider gear(s). I've removed the third member and am now pretty sure that's it - I know it's not the differential bearings.
Is this likely to be the result of the thrust washer(s) deteriorating? Should I just go ahead and install a spider repair kit like this one from Yukon?
Auto Parts: YPKF9-S-28-2 - Yukon standard open spider gear kit for 8 and 9 Ford with 28 spline axles and 2-pinion design. Yukon uses higher quality materials and better techniques than OEM to ensure a longer lasting spider gear set. All components co
Any help appreciated
Steve
8.8 clutch pack and spider gear install east302 1987 - 1996 F150 & Larger F-Series Trucks 4 06-15-2016 08:52 PM
Three Spider Gear for Sterling 10.25 axle nonrev321 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-27-2016 12:29 PM
9 inch 31 spline conversion twitbeck 1957 - 1960 F100 & Larger F-Series Trucks 13 03-21-2014 08:15 PM
Ford 8.8 Front and Rear axle set BlueOvalBud Offroad & 4x4 1 01-22-2013 08:28 AM
Ford 9" info needed will 31 spline fit 28 spline housing? overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 13 06-22-2011 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
