Ford 9" carrier dimensions - for 9 3/8" diff center - Ford Truck Enthusiasts Forums
Old 12-29-2013, 08:32 PM
Ford938 Ford938 is offline
Ford938 is starting off with a positive reputation.
Gents,
I've got a few questions with respect to Ford 9" and 9 3/8" differentials, and I was wondering if you could be so kind as to give me some insight. I've picked up a used 9 3/8" diff centre with 3.5 gears, 31 splines and a limited slip diff. The 9 3/8" differentials came in some 1971-75 Fords and Lincolns.
The ring gear is 9 3/8", not 9" and the carrier is slightly larger than the 9" carrier. The diff housing and axles are interchangable with standard 9" components. You can put a 9" in a 9 3/8" housing just fine, but you will need to grind a 9" housing for ring gear clearance to put a 9 3/8" in a 9" housing. I have read that the 9 3/8" third members were all cast from nodular iron and are stronger than any factory 9" third member.
I would like to exchange the diff with a Detroit Locker and am wondering if you knew what the ring gear register diameter and bolt pattern circle diameters on a standard Ford 9" diff were? From what I've gathered, these dimensions are the same for all Ford 8", 8.8" and 9" diffs, but I have not found any info on whether or not they are also similar to the 9 3/8" diffs.
I would like to find out what custom machine work needs to be done if I wanted to exchange that 9 3/8" diff centre with a Detroit locker (31 spline Ford 9").
Old 12-29-2013, 08:34 PM
Here some pictures of the 9 3/8" diff center:
Old 12-29-2013, 09:13 PM
Here an image comparing a Ford 9" carrier (limited slip, left) with a Ford 9 3/8" carrier (also limited slip, right). There is a small chance that the bolt circle diameter is the same on both units - if that is indeed the case one can use any 9" diff centre in a 9 3/8" diff. Of course, one would have to make a spacer for centering the larger 9 3/8" ring gear on the 9" diff center.
Carrier, Gears, Locker D-rat WTB - Parts & other 4 11-16-2016 04:45 PM
WTB: 1966-1972 truck/66-99 police car gears - 3.50 ratio - 9 3/8" diff - C6AZ-4209-B FORDF250HDXLT WTB - Parts & other 6 06-20-2016 08:23 PM
9 3/8 differential whiskey runner 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-26-2015 05:59 PM
Upgrading from 9 3/8" rear end 68Ford4Life 1967 - 1972 F-100 & Larger F-Series Trucks 24 01-10-2014 08:03 PM
Help with 9" axle weirdness, 28 vs 31 spline, bearing selection, with pics? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-20-2012 02:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
