Explorer 8.8 Rear End - Ford Truck Enthusiasts Forums
Old 12-29-2013, 05:44 PM
dferrell5 dferrell5 is offline
dferrell5 is starting off with a positive reputation.
For those of you that have went with the Explorer 8.8 rear end in your 48-50 F1, are their any modifications that you had to do. Is the Explorer track the same as the F1? Did you have to do anything special to get everything to line up? I am thinking of going with an 8.8 instead of the 8.5 that I currently have and wanted to get some information to make an informed decision. Thanks!!!
Old 12-30-2013, 05:24 PM
tip49's Avatar
tip49 tip49 is offline
tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.
8.8 rear
I used the 2001 Explorer 3:73 rear in my '50; ended up using 3.75 backspaced rims from late 80's Mopar 15" rims to increase the clearance between tire and box. I removed the spring and shock perches to align the pinion angle. I used 1990 Nissan Pathfinder springs, mounted at stock perch location, axle is mounted on top of springs to lower the back by about 3", as I recall.
Couple pics in my gallery under rear install.
Tom
8.8 explorer rear end ETOWN55 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 01-24-2015 08:14 AM
8.8 rear end from an explorer to and f150 Pearlwhite94 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2015 04:53 PM
8.8 rear end onto a 1955 F100 ETOWN55 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-17-2014 11:28 PM
Explorer 8.8 Rear End dferrell5 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-25-2014 02:26 PM
8.8 AXEL HELP!!! :) big schott 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 12-13-2013 07:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
