Rear axle hub dimensions 28 spline 9"
12-28-2013, 08:43 PM
on
Hi all,
Does anyone have the dimensions of the hub on the axles of a 28 spline 9" from the 60s? Specifically the diameter,
Thanks
12-28-2013, 09:05 PM
on
Mine measures 7.625 (7 1/16) overall diameter. The raised portion in the center is 1.875 (1 7/8). Hope this helps.
12-28-2013, 09:38 PM
on
Yes the center part....what yr is your rear?
thanks
12-28-2013, 11:02 PM
on
I'm not sure of the year but based on the backside of the center section and the 1 3/4 inch brakes I believe it is pre 1968.
12-29-2013, 01:02 AM
B7TZ-4234-A (replaced B7C-4234-A) .. 28 Spline Axle Shaft-R/L same / 1957/67 F100, all have 11" x 1 3/4" rear brakes.
Pic: Column left, scroll down to the 10th part number.
12-29-2013, 07:46 AM
on
Thanks Bill, I thought that's what it was. Knowing for sure will help when I eventually replace the brakes. I already upgraded to a Tru Track and 31 spline axles.
12-29-2013, 08:40 PM
on
ErrorS
01-26-2008 07:37 AM
whiz
13
03-27-2007 08:42 AM
scottie2hottie
08-12-2004 03:53 PM
AGATE
05-16-2004 03:10 AM
