ultimate goof - Ford Truck Enthusiasts Forums
ultimate goof
Old 12-29-2013, 03:09 PM
newguy399 newguy399 is offline
newguy399 is starting off with a positive reputation.
ultimate goof
Hey guys made a ugly bubo. Was changing the outer bearing cup in the rotor from speedway and,put the new one in backwards and before I realized it was to late.what are my options now.
Old 12-29-2013, 03:26 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
You should be able to turn it over and punch it out with a long flat-faced punch. There should be enough of an edge to catch the punch. Just make small hits as you work your way around, hitting it on opposite sides. Knock any burrs off and put it back in the correct way.
I can think of a lot of more serious mistakes that I have made. None unsurvivable.
Old 12-29-2013, 03:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You "might" be able to slip the cone in from the other side and press the race out. It still may dent the race surfaces tho.
Old 12-29-2013, 04:07 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Are you talking about the bearing adapter that fits on the spindle? If so heat it up with a propne torch and wedge a chisel between the adaptor and slindle body. It should come off easy. then re install it. Good luck.
Old 12-29-2013, 05:07 PM
toby tough's Avatar
toby tough toby tough is offline
toby tough has a good reputation on FTE.toby tough has a good reputation on FTE.
Maybe you can find a big socket that would match the circumference.Wqw, that was a big word for me. Tap it out nice and easy.
Old 12-29-2013, 07:42 PM
Thanks guys its not the adaptater that goes on the spindle,its on the rotor, I will try those tips thanks guys
Old 12-29-2013, 08:17 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
If those ideas don't work on your reverse installed cup , and I suspect that there won't be any edge presenting itself to drive against . You can take a cold chisel and create some exposure against which to use a punch .
Old 12-29-2013, 08:23 PM
oldmerc's Avatar
oldmerc
And by the way i've pulled off way worse than that i'm proud to say . One occasion that comes to mind was welding my truck inside a steel rail corral .
Old 12-29-2013, 08:39 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
Not me but a favorite of mine.A friend in highschool changed a quarter panel on his 71 chevelle.Meanwhile they stored the mint back bumper in the trunk.
Guess what had to be cut in half to remove!
Old 12-29-2013, 08:51 PM
That makes me feel better thanks for all the help
Old 12-29-2013, 08:53 PM
That was 20 yrs ago and still gets brought up once in a while.A true classic goof!
Old 12-29-2013, 11:16 PM
oldmerc's Avatar
oldmerc
Yeah no one reminds you of your brilliant accomplishments any to often .
Old 12-29-2013, 11:40 PM
Just got the cup out without damage,1-1/8 socket and a big f**king hamer
thanks again guys
Old 12-30-2013, 02:32 AM
nassi nassi is offline
nassi is starting off with a positive reputation.
Quote:
It would have been pricless to see your face when you realised.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 11:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
