'52 F5 239 valve guide types - Ford Truck Enthusiasts Forums
Old 12-29-2013, 02:35 PM
Seattle50 Seattle50 is offline
Seattle50 is starting off with a positive reputation.
Hey folks! I'm slowly working to get my F5 into operating condition. So far, with help from the forum, managed to get to a point where I have all the valves out, unstuck, and cleaned up. My question now is why do I have 2 valve guides that look different than the others. There is a rubber ring where my forefinger is but the other guides are solid. Any clues? I broke 3 guides while getting them out and need to replace em. Tanks in advance!!
I've got another valve related question to post but that's another thread.
Old 12-29-2013, 03:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Used to be that Ford only put the groove for the seal on intake guides, but nowadays all replacements come with it. Whether or not yuou want to put a seal on exhausts is a matter of some debate. Best idea I've heard is to get O-rings that fit the groove, they seal just as well but aren't as likely to attach themselves semi-permanently to the guide bores.
Old 12-31-2013, 04:16 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
You can still get the no groove guides for the exhaust: Valve Guides [35] - $69.00 : Red's Headers, Speed Equipment For Old Fords
They will sell you the guides individually if you contact them.
Old 12-31-2013, 04:30 PM
Hey 38 -
Thanks for the clue. I'll have to check if any of the broken ones were the solid type. I kind of jumped around taking the easier guides out first and letting the stubborn ones soak. Each valve assembly is bagged and marked though. I'll have to check the types out when I get back to the shop. Thanks again.
1964 f100 Color Identification DGMFORD 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-17-2015 01:28 PM
'52 F5 valve seat condition - could be trouble! Seattle50 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 12-31-2013 02:23 PM
Ford Bronco / F150 / F250 15" Wagon Wheels aeldk5g Ford Truck Parts for Sale 2 06-03-2013 10:28 AM
Newby - Lloyd aeldk5g S. California Chapter 6 06-02-2013 02:18 PM
F150 / Bronco Steel Wheels ? aeldk5g 1968-2013 Full Size Vans 0 05-14-2013 11:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
