07 miss firing? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 miss firing?
Old 12-29-2013, 11:54 AM
edys22 edys22 is offline
edys22 is starting off with a positive reputation.
07 miss firing?
I'm stumped and looking for some help. I have a 2007 expedition with 110,000 miles on it and it starting running very rough yesterday. I had driven the truck yesterday for about an hour and half with no issues. On my home I was really low on fuel and filled it up. After filling it up, I drove home (5miles) again with no issues. Later in the day my wife took it out and returned immediately because it was running so rough and the check engine light came on, she only made it down the block. I drove it up to the parts store and here are codes they pulled - P0022,P0018,P0305,P0300,P0307 & P0316. So here is where it gets weird, I leave the parts stores and the truck runs perfect so I do some running around with no issues. When I get home I disconnect the battery to clear the codes. Later last night I take it out and it immediately starts acting up again so this morning I run back to the parts store and it now only shows code P0018. Again, I leave the store after pulling the codes and the truck runs fine. I changed the plugs 10,000 miles ago and there have been no other issues until this.... Any ideas? Thanks in advance
Old 12-29-2013, 12:24 PM
mrjones111 mrjones111 is offline
mrjones111 is starting off with a positive reputation.
That code shows as a crankshaft position sensor.
Old 12-29-2013, 01:01 PM
if the crankshaft sensor was bad wouldn't it no start or run bad all the time?
Old 12-30-2013, 01:47 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Take it to a mechanic you trust. That many codes there might be something serious. People who replace sensors based on codes usually end up taking it in anyway.
Old 12-30-2013, 11:21 PM
bunky383 bunky383 is offline
bunky383 is starting off with a positive reputation.
a bad or intermittent signal from your crank sensor can definitely cause your misfires/misfire codes (P0305,P0300,P0307 & P0316). if your pcm can't determine the correlation between cam and crank, then it doesn't have a hot clue when to fire your coils/injectors.
Please Help with engine stalling Roscoe316 6.0L Power Stroke Diesel 28 10-21-2016 08:51 PM
Turbo won't stop hunting!!! Restlesswildman 6.0L Power Stroke Diesel 25 06-15-2016 04:04 PM
rebuilt transmission flashing O/D light with codes mototrig 1999 - 2003 7.3L Power Stroke Diesel 18 03-22-2016 09:22 AM
2007 Ford F150 Lariat 5.4l Triton Misfire Issues 116,000 lballard1129 2004 - 2008 F150 11 12-01-2015 07:08 PM
07 F-150 - Hesitation, rough idle, various codes tspangle84 2004 - 2008 F150 5 02-09-2010 01:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
