226 small crack in block help - Page 2 - Ford Truck Enthusiasts Forums
Old 12-29-2013, 03:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Valves on the flat-6 are adjustable AFAIK.
Old 12-29-2013, 03:24 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by vafinest540 View Post
I got the truck last week. I would have never realized it had a very small crack till I cleaned the dirt damp spot. And drove around and it came back. That's a pretty informational video def think I will be thing something just happy to here that its not trash now.
Are the flat motors typically noisy in the valve department? Specially idle? Like the lifters tapping noise it sounds like all 12 valves making same noise. Gauge oil pressure is 5-30psi. Depending on rpm. Might be time to get block machined. What do you all think. Thank you all for the good tips!
Have you changed the oil yet? What weight did you use?
I also have a 226 I6. I ask because my oil pressure was 15 psi at idle and 30 psi running until I dropped the oil pan, cleaned the screen and refilled with 20W50. Now my pressure is just above 30 on the gauge at idle, which is much better than before. And it's about 45 pounds at higher RPM.
Old 12-29-2013, 03:37 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Ford made access to the six cylinder valve adjustment easier by making an access panel through the passenger side inner fender.
Old 12-29-2013, 03:48 PM
vafinest540 vafinest540 is offline
vafinest540 is starting off with a positive reputation.
I'm not sure the weight now but 30 weight or 20/50 will be going in. I need to drop pan and replace seals. I'm hoping gauge pressure goes up and tapping goes away when strainer screen is cleaned. With the crack in the block I was not sure on route was going to take. seems like its common practice on these flatte motors. Wasn't sure what to expect with oil pressure eather but 30psi idle sounds good opposed to my 2-10.
Old 12-29-2013, 03:53 PM
ALBUQ F-1's Avatar
postin' fool
Oil quality/weight has no effect on tappet noise, they aren't hydraulic lifters.
Old 12-29-2013, 04:01 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I think what Ross is saying is that ya need to adjust the valves to make the noise go away.
Old 12-29-2013, 05:04 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
This is the normal stitching pin repair procedure (below). I have a block that needs the same repair, a 3" long freeze crack above the pan rail. I was quoted $140 for a pro to repair it and some other cracks on the deck.
Cast Iron Crack repair - YouTube
Ross I really enjoyed this video. I've heard of the procedure B4 but had no idea what it was. Thanks for posting it.
226 Clutch Housing (Bell Housing) Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 01-10-2015 06:07 PM
226 rear main bearing cap Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-20-2014 04:30 PM
CC826 Moog coils for cheap 2.5" lift Dlasure2 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2013 02:12 PM
Warn Hub Install **Lots of Pics** afreemanmd Excursion - King of SUVs 24 08-02-2010 05:38 PM
Rebuilding 1948 226 Flathead dcicci 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-26-2010 11:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
