2008 F350 dually front suspension swap - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-28-2013, 09:14 PM
Madwookie308 Madwookie308 is offline
Madwookie308 is starting off with a positive reputation.
Has anyone tried to put a heavy front end from an 2008 F450 on a standard 2008 F350 dually? Thinking about doing it, any information greatly appreciated.
Old 12-28-2013, 09:47 PM
rollerstud98's Avatar
rollerstud98 rollerstud98 is offline
rollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud of
What do you want to do it for? Looking for more capacity or mainly the tighter turning? There were a couple years that the wide axle was an option on the F350 as well. I'd look more in to that for your application just cause it should be easier to just bolt up.
Old 12-28-2013, 10:08 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
You won't gane any legal capacity. The door sticker is what you have to go by.
But the ultimate factor is the tires.
Sean
Old 12-29-2013, 05:45 AM
The turning ability of a heavy front end is the reason, especially for my crew cab long bed. Thanks for the information.
Old 12-29-2013, 09:26 AM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
I would think it should be easy for a competent front-end shop. But you would have 2 different bolt patterns front to rear, plus the gear-ratios would need to be changed from 4.30 or 4.88, depending on which you put in.
But, I agree, the decreased turning radius is really handy.
Joe
Old 12-29-2013, 11:23 AM
My truck has 4.30 gears already so that is one problem solved, I had heard that the front hubs would transfer to the heavy front end but have not confirmed it.
Old 12-29-2013, 02:01 PM
Mud Doc's Avatar
Not only 2 different bolt patterns, different wheel sizes. 17" vs 19.5" If you are willing to change the wheels and tires, then it doesn't sound like too hard a project. You would need 8 to 10 bolt adapters for the rear.
Need to ask some front-end shops, but that is probably going to be a another problem--I haven't found many shop familiar with the 450 front ends.
Joe
2008 front wheel hub assembly northernsuperduty 1999 to 2016 Super Duty 1 03-07-2015 01:26 PM
2008 ford f350 box upgrade serge.segovia 1999 to 2016 Super Duty 0 09-27-2014 08:11 PM
empty vehicle weight - 2008 f-350 CC V-10 Dually speakerfritz 1999 to 2016 Super Duty 4 07-18-2014 12:06 AM
F-350 vs F-450 jettex 1999 to 2016 Super Duty 15 03-04-2014 07:17 PM
2008 F350 Headlights bookem15 1999 to 2016 Super Duty 23 02-26-2014 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
