95 7.3 won't run after replacing oil cooler
Hi there I'm wondering if anyone has any ideas about a prob I'm having I recently replaced my fuel pump the my oil cooler started leaking so I replaced it once I finished I started the truck and backed it out of the garage it died and wouldn't start again once in a while it will start for about 10 seconds then die I've replaced the fuel pump again thinking maybe it was bad and replaced the fuel lines thinking maybe there was a hole in one so the pump couldn't pull fuel but still no luck truck just cranks if I fill the fuel bowel to the top and put the cover on it will run for about 10 seconds then die again I've replaced the oil cooler on my other trucks before and had no issues with starting or running after not sure what else to check any ideas would b greatly appreciated thank you
BryanStein
10-21-2014 08:13 AM
shoddymill
24
11-12-2009 06:16 AM
HeatStroked
06-25-2006 07:47 PM
