OK,
when I purchased my 65 F100,the w/s washer nozzles were all that was present of the washer system. So today I replaced the windshield washer system -- new pump power button, new pump, new hoses, new reservoir and I cleaned the nozzles. The problem is there is very low water pressure coming from the nozzles -- water barely gets to the windshield. So, what have I missed or what needs to be done to increase the spray pressure?
If you unplug the hose at the splitter under the hood you should get a pretty good squirt with all those new parts. I suspect the nozzles might need more attention. I've cleaned them with a thin strand of copper wire and found success.
Eric
Thanks Eric, I did run a strand of wire thru both water holes in both nozzles. Additionally, I blew them out with compressed air from the nozzle openings back thru the inlet stem.
Well, that's the only thing I have not done....I'll give it a try tonight and get back to the board.
Well, I've done everything suggested and still have low nozzle pressure. I've concluded that the "new" pump must be bad...now to see if the vendor will accept to for an exchange/refund.
Thanks to all for your support!
Well, it was a bad pump. I returned the repop and found a NOS unit on eBay (that was cheaper than the repop) and the washer spray is great!
