H9 Axle code - Both 8.8 and 9.75? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 12-28-2013, 05:05 PM
Turbocapri Turbocapri is offline
Turbocapri is starting off with a positive reputation.
Hi Guys,
I just bought a 98 Expedition with a bad rear axle. The carrier bearings failed and it's pretty messed up.
The door axle code is H9. The tag on the axle identifies it as an 8.8" 3.55 ratio locking rear.
I've found a 2001 Expedition in a local PIY yard that also has the H9 axle code on the door sticker. However, the tag on the rear identifies it as a 9.75" 3.55 ratio locker.
If I pull the rear out of the 2001 I can get it for $100.
So, is there any reason I can't put a 9.75" rear in the truck? Any other parts I should get? Perhaps the driveshaft from the 2001?
Thanks.
Old 12-28-2013, 08:25 PM
Some answers to my own questions from searching.
There are 2 issues, one real and one potential.
Beginning in 2000 the wheel stud size increased to 14 mm from 12 mm. That provokes interference with the rotors and the wheels. I suppose I could put a set of axles from a pre 2000 9.75 in.
The other issue is driveshaft length. Apparently the 9.75 is about 1" longer than the 8.8. However, I've seen posts that say this is and isn't a problem. Anyone know?
Old 12-29-2013, 07:14 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
It isn't going to be a good deal if it doesn't fit.
Old 12-29-2013, 07:57 AM
Quote:
Yes, at this point I'm inclined to rebuild the 8.8. It's out of the truck and will be up on a bench in the garage later today.
I really don't want the hassles of having 12 mm studs on the front wheels and 14 mm studs on the rear.
8.8 or 9.75 rear axle? AUTOHAUL 2015+ F150 14 09-24-2016 04:37 PM
Ring Gear Size bluecobra 1997 - 2003 F150 6 07-01-2014 04:50 PM
8.8 to 9.75 axle swap 97chevy eater. 1997 - 2003 F150 28 09-07-2011 11:05 PM
Ring Gear size? Golflug 1997 - 2003 F150 3 02-16-2011 12:45 PM
2010 F150 front and rear axle driptorch970 2009 - 2014 F150 1 12-16-2010 05:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
