Garage heat - Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
Garage heat
Old 12-28-2013, 03:50 PM
sd1972 sd1972 is offline
sd1972 is starting off with a positive reputation.
Garage heat
Just a question do any of you guys heat your garage/workshop? If so what do you use? I am getting for waiting for warm days to work on my truck or other projects.
Old 12-28-2013, 04:42 PM
flyboy2610's Avatar
flyboy2610 flyboy2610 is offline
flyboy2610 is gaining momentum as a positive member of FTE.
Garage? What garage?
Old 12-30-2013, 12:11 PM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Hey David. All I have right now is this 240V little box heater from Northern tool. Works okay when it's about 25 degree's or more, otherwise it's too small.
NewAir Electric Garage Heater — 19,107 BTU, 240 Volts, Model# G56 | Electric Garage Industrial Heaters| Northern Tool + Equipment
I would have done a propane, but I don't have the venting necessary for it.
Old 12-30-2013, 12:24 PM
jseim44's Avatar
jseim44 jseim44 is offline
jseim44 is gaining momentum as a positive member of FTE.jseim44 is gaining momentum as a positive member of FTE.
When I lived in town my shop had electric baseboard heaters in it. Not the most efficient, but it was warm. I've also got a Knipco style propane heater that works well. Not as stinky as the kerosene ones but still need some ventilation. I've thought a wood stove would be alright, but it's a bit harder to control the heat.
Dad has the infared propane ones. They are OK but it's about 1000 degrees under them, then the farther away you get the colder it is.
The floor heat in out shop at work is REALLY nice!
ANY heat is better than NO heat
-Jake
Old 12-31-2013, 10:21 AM
67nukeford's Avatar
I plan on using a heated floor, when I put up my shop.
Old 01-14-2014, 12:23 AM
eviiltim72's Avatar
eviiltim72 eviiltim72 is offline
eviiltim72 is starting off with a positive reputation.
I am just using a small propane forced air heater. It's about 45,000 btu and heats my 2 car garage to about 80 when its below freezing outside in less than an hour.
Upgrade to Heated Mirrors rod250 1999 to 2016 Super Duty 17 02-04-2014 01:14 PM
garage wiring help. What did you do/would you change? mustang_gt_350 General NON-Automotive Conversation 44 03-11-2013 04:19 PM
Garage help Dotnodrog51 User Gallery & Picture Display 1 01-08-2013 05:10 PM
frozen sheetrock 2doggs Garage & Workshop 12 06-19-2005 07:44 PM
Heating an uninsulated garage? zuikoman Garage & Workshop 25 01-19-2005 06:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
