ignition issues on a 1976 302 in my 1954 f100 - Ford Truck Enthusiasts Forums
Old 12-28-2013, 02:13 PM
Trues_01 Trues_01 is offline
Trues_01 is starting off with a positive reputation.
Ok i guess I'll start with the truck has a 302 from a '76 Maverick. It ran good before it was in a flood. I've rebuilt the motor and had it running with the old wiring that was spliced in many different places. But the alt went out and the voltage regulator went out and the coil almost at the same time. I have replaced everything except the distributor. I also ran all new wires to everything. I'm getting fire from the coil to the distributor and the truck will turn over but will not fire up. It doesn't have an ignition module just goes from the solenoid to the coil I'm lost at this point so any suggestions or wiring diagrams would be most helpful at this point.
Old 12-28-2013, 02:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
So you are running points? And you are running 12v negative ground?
If you have a 4-post solenoid, one of the small posts should be labeled "I". That one goes directly to the coil (+) terminal. In addition there has to be a wire from the IGN terminal on the ignition switch, that usually runs thru a ballast resistor to the (+) terminal on the coil. If your coil is made with an internal resistor, then you don't need an external ballast resistor, and the wire from the "I" terminal is useless.
Old 12-28-2013, 02:32 PM
The coil that i put in is an MSD Blaster 2F and I don't have the ballast resistor on it just straight wire. so I'll see if i can find one thank you for your help. also how do i post pics on here that could possibly show what im doing for further help
Old 12-28-2013, 02:39 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C9OZ-12250-A .. Resistor Wire-Ignition Coil-Marked: C9OB-12250-A (Motorcraft DY-85).
60" long / Color coded pink / 1.30-1.40 ohms resistance / #16 gauge wire.
1969/73 Fairlane/Torino/Mustang/Cougar / 1971/76 Maverick/Comet.
DuraSpark Electronic Ignition introduced in 1974, but not all vehicles came with it until 1976.
Old 12-28-2013, 02:45 PM
Also the distrutor has one wire that was connected to the coil is it supposed to be on the positive or negative side? my brother pulled it of and i need to make sure its put back in the right spot. The wiring diagram that i have says it goes on the negative side with the tac wire
Old 12-28-2013, 03:54 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is online now
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Quote:
You are correct, negative side. If you have spark from the coil to the distributor but not to the plugs? Do you have the rotor in the distributor?
Old 12-28-2013, 04:57 PM
Yes sir cap and rotor are new.
Old 12-28-2013, 06:29 PM
Rimrock F1's Avatar
How did you check for spark at plug?
Old 12-28-2013, 06:53 PM
ALBUQ F-1's Avatar
postin' fool
You need a ballast resistor with that coil
Old 01-01-2014, 04:43 PM
Hello i talked to you the other day about my ignition on my '54 f100. i got the ballast resistor and needed to know what post on my switch. there is a battery post an acc post and the ignition post. also should there be a wire from the "I" side of the solenoid to the (+) of the coil in addition to the ballast wire.
Old 01-01-2014, 04:57 PM
seaves46 seaves46 is offline
seaves46 has a good reputation on FTE.seaves46 has a good reputation on FTE.
Ballast resistor needs to be in the coil supply wire between the ign switch and the coil .
1988 F150 302, 4 cylinders not firing 88XLTLariat 1987 - 1996 F150 & Larger F-Series Trucks 9 02-14-2017 08:32 PM
390 ignition issue Tyler Burns FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 11-25-2016 08:52 PM
No start nightmare robertw567 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-02-2015 12:49 PM
1951 F2 6volt - no spark Joey4420 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-16-2015 12:46 PM
1960 F350 Ignition Issues JGuillen99 1957 - 1960 F100 & Larger F-Series Trucks 1 04-23-2015 06:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
