In one piece, sort of... - Ford Truck Enthusiasts Forums
Old 12-28-2013, 12:43 PM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
To make room in my shop, I had to consolidate all the truck body parts that were lying around. This is the first time that this old truck has actually looked anything like a vehicle in many years. While it doesn't look like much here, having it (sort of) back together at all seems like a minor triumph for me, so I decided to post a photo. I am hopeful that late next spring I finally paint the whole thing. Body work included a lot of hammering out of dings and dents, patching both rear fenders, rear cab corners, both front lower cowl sections, inner fenders, bed post pockets, floor sections and replacing a rusted section of the roof with a solid piece from a donor cab. The front fenders are poorly made reproductions which will require work to fit and look decently. The engine has been ready to go for years, and waits patiently to be re-installed. All body pieces are coated with either a light spray of rattle-can primer (which I will remove prior to epoxy priming) or PickleX 20 metal prep, so it's not a rusty mess when I return to work on it again come warm weather. I am still getting the whole hood/hinge thing worked out following Ax's step by step front end assembly instructions. So far, so good. I may end up with one of the few trucks like this that won't require me to go to each rear hood corner and press it into a fully closed position...
Old 12-28-2013, 02:46 PM
Rojak Rojak is offline
Rojak is gaining momentum as a positive member of FTE.Rojak is gaining momentum as a positive member of FTE.
What a great way to consolidate parts! Looking good. Keep us posted on your progress.
Old 12-28-2013, 05:21 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Looks great. That should give you inspiration to get going. Good luck.
F1 fender rust repair and patch forming. TRY 2 AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 108 09-27-2016 09:04 PM
1954 f100 Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 280 09-06-2016 02:58 PM
Rust repair and patch panel forming AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-02-2014 12:43 PM
2.5kW inverter, RF equipment, Rack install (Note: Many images to load) TRENT310 1999 to 2016 Super Duty 13 10-26-2014 03:46 AM
Offroad Cab Cage?? 73 ford guy Offroad & 4x4 39 08-13-2010 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
