2014 SD w/6.2L..reviews??
#46
#48
#49
My truck makes the audible alarm as soon as I go in to reverse only if there is frost build up on the sensor near the exhaust. Usually the screen will light up a block on the area that it ASSUMES is close to an object. Took me a while to figure out it was just frost build up from the exhaust
#50
#52
#53
#54
Mine is averaging 13 mpg's ,,all city so far, it may improve when things warm up and get rid of winter fuels,,we will see..Right now I am chasing 2 issues in my 14. A vibration in 6th gear 45-50..and a dry bushing/joint noise coming from front left, you hear it when from dips down into a turn or hump..Annoying as hell for a brand new truck..
#55
#56
It was a bad body bushing in the right rear cab. Dealer replaced it and now it is back to being. As quiet as a mouse!
#57
yours was rear bushing,, mine is front left..are there Body Bushings in the front left of the cab,, do you know where I should look for it?
#58
Yeah mine was in the rear..... Yes there are bushings in all 4 corners. Honestly I could not tell by looking at mine that it was bad. I was pretty sure that's what it was and the dealer confirmed it.
Drop it off at the dealer and let them fix it..... To me that's one of the reasons I bought a new truck....... So I didn't have to work on it.
#59
#60
Well a lot of the time it can depend on the dealer and the level of their techs. I have worked at several dealers and they are all different.
I am not there and it's only a guess but I can not imagine why they would even have to call Ford. That typically does not happen until several inspections from the best techs and shop Forman can not fix the issue. Sounds like that tech either didn't know what he was doing or more than likely wanted to get you out and away from the truck to fix it.
My truck has been to the dealer twice..... Once for the bad body bushing and the other was a squeaky tail shaft seal. Both were minor repairs and both were good experiences.
I understand how you feel but even new vehicles can have problems...... Even the Subaru's other imports out there.
Give the dealer a day or two and see what they come up with.
This is my first Ford truck and so far I am very happy even with the minor issues. I would never consider an import for a big HD truck. I like Dodges new trucks and I have always been a Chevy guy. When it comes to a truck..... For me it's gonna be a big American gas guzzler!!!!
Best of luck with your rig....... I am sure they will fix it.
