2014 SD w/6.2L..reviews?? - Page 3 - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
  #31
Old 02-08-2014, 10:27 AM
Hotrod70d's Avatar
Hotrod70d Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
does anyone know if a tuner will turn off the traction control. i know they doon my mustang there a pain. also my truck didnt pick up mileage till after 5k miles.the mileage is also down now to it sitting and idleing to warm up in winter and the winterblend gas drags down mileage. i was at 13.4 mpg last summer, trucks down to 12.9 to 13 mpg now . im assumiong it will go back to 13.4 this spring. truck has 10k on it now.
  #32
Old 02-08-2014, 01:24 PM
saltbranch saltbranch is offline
saltbranch is starting off with a positive reputation.
Quote:
Originally Posted by Go Big or Go Home! View Post
I would be thrilled..I would be thrilled if it will operate and run w/o issue for a 100k..thats more important than mpg's..
That played a big role in why I went with the 6.2, I have owned diesels since 1984 and the 6.9. The new diesels are not the bullet proof beasts of the past.
After all the trouble I dealt with on our company 6.0/6.4's. Also from a friends hot shot trucks...he runs 35 different 6.7 Ford and Dodge 1 ton diesels and has had a lot of issues with both. He is even going to gassers now for the new replacement trucks.
  #33
Old 02-08-2014, 01:31 PM
jeepnford jeepnford is offline
jeepnford is starting off with a positive reputation.
My 7.3 only gets about 11 mpg pulling a 6k camper. If my new 6.2 gets 9-10 I figure I'm ahead.
  #34
Old 02-08-2014, 01:59 PM
brickman brickman is offline
brickman is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Amelio View Post
Omg what I going on with your rig? 6mpg does not sound anywhere close to right with a 7k trailer unless you drive everywhere with your foot to the floor??????
I have not towed my new 28' trailer but my old one with my car and tools was probable close to 6k and my truck would do 12.5 on the hwy
My truck has 15k miles now and I average roughly 13mpg city driving. On the hwy at 65mph it will do 15-16 and sometimes bump 17 if its flat this is empty of course.
I am not at all worried about longevity with this engine. The 6.2 has already proven to be good past 100k miles with little to no problems.
With my new trailer I hope to get at least 10mpg ..... The trailer should come in close to 9k loaded. But then again it's only 100 mile trips to the race track so it's not that big of a deal if it doesn't.
I am curious to what my city driving mpg goes to with the 2.5" lift and 35's I plan to put on.
Umm I think you may want to re read what I posted .. It wasn't anything about mpg ,or towing ..
  #35
Old 02-08-2014, 03:18 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Quote:
Also remember the 6.2 doesn't need DEF just straight cheaper gas, when the diesel crowd are taking milage and cost they seem to forget about it when figuring their costs.
Denny
  #36
Old 02-08-2014, 03:41 PM
They also don't take into consideration the extra financing . In Canada the 6.7 is an extra $10,000.00 which adds another $1,300.00 HST plus an additional ~ $3,000.00 in financing costs ,if taken out over 5 yrs @ 5.5%(correct me if I am wrong) which amounts a $14,000.00 premium over a 6.2 ltr. I could buy a whole nuther car for that..
  #37
Old 02-08-2014, 04:40 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
Quote:
Lmao!!!!! My bad for some reason I saw 5'6 and understood it as 5.6 as in mpg lol.......
Well then thank goodness for the adjustable pedals.....
  #38
Old 02-08-2014, 04:53 PM
I think I would be at the dealer if it was only getting 5.6 mpg That would be scary!! I had to modify the gas pedal myself cause the truck didn't come with adjustable pedals.
  #39
Old 02-08-2014, 07:27 PM
rvpuller's Avatar
When we ordered ours the adjustable petals were a must, my wife's only 4ft 10in.
Denny
  #40
Old 02-10-2014, 06:10 PM
reagan4ever reagan4ever is offline
reagan4ever is starting off with a positive reputation.
out with the 6.4 in with the 6.2
unloading the 6.4 tomorrow for a 2014 F350 CC 6.2 gasser. The maintenance cost of the 6.4 at 99k miles is becoming too much. Cannot justify $8400 for a diesel when the rest of the truck is the same. Wish me luck looking forward to the 6.2l
  #41
Old 02-10-2014, 06:34 PM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Quote:
good luck, I just got the 14SD F250 with the 6.2L.. Like u I couldn't justify the diesel/cost/expense/fuel..etc.,,I like this 6.2L so far..(bit noisy) but it is a step up from my 5.4 I had in my 2002 SD..
  #42
Old 02-10-2014, 06:44 PM
My new 6.2 should be here in about a week. I have to admit I was a little apprehensive about going gas. However, driving home from work today with the temp about 10 degrees the temp gauge never approached normal. I realize a gasser will be about the same but it's not quite as worrisome as a diesel. I don't tow enough or drive far enough for an oil burner.
  #43
Old 02-10-2014, 08:42 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Good luck. Oh and, love your username! Oh for the days when we had a real president
  #44
Old 02-11-2014, 08:57 AM
22rimfire, i too miss those days when we had common sense in stead of non-sense! One day ownership and first problem arises. The rear camera backup sensor goes on whenever you go into reverse. Back to dealer today. I read that there is a reset that needs to be done after replacing the sensor. Simply disconnect the battery for a few minutes. Let's see what tomorrow brings! Keep the faith.
  #45
Old 02-11-2014, 09:05 PM
Am I missing something ? isn't that what it's supposed to do?
2017 Expedition EL Platinum or F-250 CC, 8' SWB?? iya0yas 2017 Super Duty 18 09-23-2016 08:54 AM
Are 6.2L Ford SD's good trucks? OUTLAW714 1999 to 2016 Super Duty 24 05-31-2016 10:12 AM
Is the 6.2L in the 250 SD the same as a Raptor? JimRay Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 7 04-26-2014 06:26 PM
Opinions/advice on new truck please... Randall1984 6.2L V8 11 04-10-2014 10:31 AM
6.7 hood insulation 2013SD6.2 6.7L Power Stroke Diesel 29 04-04-2014 11:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
