2007 F250 5.4 in 2006 F150 5.4 will it work? - Ford Truck Enthusiasts Forums
Old 12-28-2013, 10:09 AM
knipdlo knipdlo is offline
knipdlo is starting off with a positive reputation.
2006 F150 KingRanch 4x4 Flex gave up the ghost at 324k.. need to find a motor to replace it with- found a 2007 5.4L from a F250.. low miles.
Will it be a direct fit? if not what needs to be swapped over?
Other option is a 2007 F150 engine, but it has higher miles.
Thx,
Tim
Old 12-29-2013, 09:16 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
Thx,
Tim
Tim
Sorry I don't have the details that you looking for...but off hand it should be a direct swap, it is within the same generation. If the "new donor" engine is out of another F150 & not a expedition or van...should be straight up swap. Take Lots of pictures of everything, before, you start of both current engine and of the donor as well as taking notes. Can't imagine that there won't be anything that couldn't be transferred to the "new donor".
Might be wise to chatt with local dealerships techs or local salvage yards....they should be able to provide some insight as well.
Old 12-29-2013, 11:06 AM
Thanks for the reply enriched&beyond.. gotta figure out something soon! That F250 motor sold.. so back to looking for other options.
Old 12-29-2013, 11:32 AM
Leon82 Leon82 is offline
Leon82 is starting off with a positive reputation.
some of the accessory brackets or locations may be different, but you should be able to swap them over easily
Old 12-29-2013, 12:25 PM
Can anyone tell me what is different between the FFV and non FFV? I have a V in the 8th digit place of my VIN, but I found a good deal on a F150 motor from a wrecked 2007 that is just a regular gas..
Probably need to use my intake/injectors/fuel rails... anything else?
Old 12-29-2013, 12:52 PM
Flex fuel vehicle.
The short awnser is to never use e85 if you use that engine
If i had to guess i would say the computer is different also
Old 12-29-2013, 12:54 PM
yeah I'd never use e85 to begin with lol, just don't want any codes or check engine lights because NY requires you to plug in the computer to pass emissions..
2007 5.4 Gas Eng Swap for Flex Fuel Eng Texasteddy 2004 - 2008 F150 11 09-17-2016 10:44 PM
2006 f150 5.4 huckster 2004 - 2008 F150 0 06-25-2015 03:16 PM
Best plugs for 5.4L docweld 2004 - 2008 F150 22 02-10-2013 03:41 PM
5.4 tune up baracade 2004 - 2008 F150 7 07-23-2010 12:27 AM
headers dahunter_2007 1999 to 2016 Super Duty 7 02-23-2010 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
