CV Swap Ride Height - Ford Truck Enthusiasts Forums
CV Swap Ride Height
Old 12-27-2013, 09:18 PM
Neschenbrenner001 Neschenbrenner001 is offline
Neschenbrenner001 is starting off with a positive reputation.
CV Swap Ride Height
Was wondering if anyone could tell me if there was a way to do the CV swap and keep original ride height or only an 1-2" of drop?
Old 12-28-2013, 07:24 PM
6t6merc 6t6merc is online now
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
I can't answer your question but I would also like to learn the answer. It is obvious that if the spacers were placed under the frame, the truck's ride height would be relatively higher. None of the conversions I have seen online do that. Maybe if that is done the trailing arms miss the frame?
Eric
Old 12-29-2013, 10:28 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
You build mounts for the rear of the lower control arms that drop down lower. There is a guy who blocked his under the chassis but I do not view that truck as safe so I am not going to give any links. The basic process is to add material under the rail & flip the upper shock tower support over.
Old 12-31-2013, 09:27 AM
THE HOGG THE HOGG is offline
THE HOGG is starting off with a positive reputation.
You could box the rear mounts down 5/8 of an inch farther and put the 5/8 frame spacers between the bottom of the frame and the cv front end and easily get 5/8" I would think. Not sure if that's enough but its some and its easy. I had to make a boxed mount on the bottom of the frame for the rear mounts anyway so the height difference there doesn't really require any more work even.
those who used the 2002 and earlier CV front end, I've got a question havi 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-14-2014 10:12 AM
Juang's CV swap build thread. juang316 1961 - 1966 F-100 & Larger F-Series Trucks 41 01-23-2014 12:11 PM
Need some pics please of complete CV swaps for ride height example SuperDuty93 1957 - 1960 F100 & Larger F-Series Trucks 20 01-05-2014 03:45 PM
59 Crown Vic Susp. Swap Questions SuperDuty93 1957 - 1960 F100 & Larger F-Series Trucks 10 12-25-2013 07:25 PM
Crown Vic - stock height? JP3 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-13-2013 11:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
