King Pin Trouble - Ford Truck Enthusiasts Forums
King Pin Trouble
Old 12-27-2013, 07:53 PM
Brian~50F3's Avatar
Brian~50F3 Brian~50F3 is online now
Brian~50F3 is starting off with a positive reputation.
King Pin Trouble
Hey everyone;
I disassembled my front suspension a few weeks ago (1950 F3), and during dis-assembly I noticed the king pin bushings on the drivers side were slightly larger than the passenger side... at first I thought maybe that side had an oversize king pin, but upon comparison (right to left, as well as compared to new pins), they were not oversize (also the axle hole is not oversize).
I continued with the cleaning of both spindles; blasted/sanded/primed/painted figuring perhaps that's just the way that side was and the new bushings would be fine... I received the new king pin kit to discover the new bushings slid completely though the holes in the spindle (see pic)...
My question is, what are my options? Also is that the stock spindle? It has a Ford stamp (barely visible in pic), but I cannot make out the numbers stamped on it. Should I replace the spindle (anyone have one? Same as F1/2), or are there oversize bushings I can pick up?
Thanks for the input!!
Pic of Ford Stamp, as well as part number stamp? Sorry, was best pic I could get
From top
From top with bushing "floating" in middle
Old 12-27-2013, 08:08 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I would say your best option would be to replace the spindles, if in fact those are the correct bushings. They are the same for F1 to F3.
Old 12-27-2013, 08:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The DS spindle must have been bored out and custom bushings made. If the spindle were from a bigger truck that used a bigger kingpin, the wheel bearings would be different, I can't believe they'd work with an F-3 drum.
F-1 thru F-3 spindles are the same, so I'd look for a new one. Should be easy to find with all the people doing MII front ends.
Old 12-27-2013, 08:39 PM
Brian~50F3's Avatar
Ross;
Your reply got me thinking... I went out and measured the king pin hole diameter on both spindles, the passenger side was appx 7/8' or .87" (prob closer to .81 if I had a micrometer), and the DS spindle (one in question) was 15/16' or .93" Could the DS spindle be a spindle for a "J" model? Which is the F3 Parcel Delivery?
Either way, I'm going to start looking for another one, just curious now...
Old 12-27-2013, 08:53 PM
ALBUQ F-1's Avatar
postin' fool
I don't think it's a J spindle, the pic in the Parts CD appears to show a much greater offset for the J.
Old 12-28-2013, 02:22 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Scroll down to: 3105-6 spindle assy.
C = F1 / D = F2 / Y = F3 // J = F3 Parcel Delivery.
Old 12-28-2013, 06:12 PM
Southernflyer Southernflyer is offline
Southernflyer is starting off with a positive reputation.
I've installed a million king pin bushing's it seems, I'm thinking you've got the wrong set.
Old 12-28-2013, 11:51 PM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
You can buy bushings from a bearing house any nominal size. Measure the bore of the spindle and your kingpin and call them & see if they can get them. Then you'll have have them pressed in and honed or reamed to fit the pin. If you are trying to build to perfect standards then you had better get the correct part.
Happy new year by the way.
Old 12-30-2013, 06:23 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
If you're still in need of a king pin, I have several. Just need to remove them.
1950 Body and Wire Questions Brian~50F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-02-2016 12:49 PM
Another 226 back from the dead Brian~50F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 04-04-2016 09:25 PM
Pressure Plate Problem Brian~50F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-09-2016 12:54 AM
Widow Maker No More Brian~50F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 04-07-2015 02:24 PM
1988 F-350, 460 EFI Having All Kinds of Issues OkieFromMuskogee 1987 - 1996 F150 & Larger F-Series Trucks 10 01-25-2015 07:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
